Chopcor Posted May 6, 2010 Share Posted May 6, 2010 I have a 99 Subaru SUS 2.5 with a bad transmission(TZ1A2ZJEBA)- Was wondering if I could use a 97 Subary Outback transmission in it's place if I was to utilize the donor trans, TCU, and wiring harness- as I understand it, both are 4.44 final drive ratio, so no problem there. The donor car trans number is TZ102Z2CBA. Thanks, Stan Link to comment Share on other sites More sharing options...
johnceggleston Posted May 6, 2010 Share Posted May 6, 2010 I have a 99 Subaru SUS 2.5 with a bad transmission(TZ1A2ZJEBA)- Was wondering if I could use a 97 Subary Outback transmission in it's place if I was to utilize the donor trans, TCU, and wiring harness- as I understand it, both are 4.44 final drive ratio, so no problem there. The donor car trans number is TZ102Z2CBA. Thanks, Stan well i know you can't use the 97 trans WITHOUT the wiring harness. the connectors are different. i have never heard of any one doing it by swapping the harness and tcu. i would be very surprised if it works, but i have been surprised before. there is a chance you might need the ecu as well but i doubt it. why not just get a 99-03 auto trans? Link to comment Share on other sites More sharing options...
