Installing rear 5 lug hubs on gen2 Brat
5 lug conversion is pretty straight forward on the rear axle (Front wheels are much more complicated).
5 lug hubs from an XT6 are are straight swap if you use the backing plate, hub, and caliper assembly from an XT6. If you've already done the rear disk upgrade, all you really need is the backing plate and hub; calipers are the same. This applies to the 4WD versions of both the donor XT6 as well as the receiving gen2 Brat.
