Uberoo Posted May 11, 2010 Share Posted May 11, 2010 Ive heard that legacy diffs are 4.11,but they also have inner stubs instead of the outer stubs.Is it possible to put the 4.11 ring and pinion gearset into a 3.9 diff housing and then just slide in the outer stubs? Quote Link to comment Share on other sites More sharing options...
Qman Posted May 11, 2010 Share Posted May 11, 2010 No Quote Link to comment Share on other sites More sharing options...
Numbchux Posted May 11, 2010 Share Posted May 11, 2010 it's not the housing that's different. it's the carrier. first gen legacies have male stubs just like EAs. All other EJs have female splines in the diff. I'm running a 4.111 rear diff from a '99 RS with the carrier from an EA turbo sedan in my XT6 right now. completely bolt-in. Quote Link to comment Share on other sites More sharing options...
baccaruda Posted May 11, 2010 Share Posted May 11, 2010 search Quote Link to comment Share on other sites More sharing options...
monstaru Posted May 12, 2010 Share Posted May 12, 2010 or, you could actually take ************ apart for once. Quote Link to comment Share on other sites More sharing options...
Qman Posted May 12, 2010 Share Posted May 12, 2010 (edited) Try again Uberoo. I am getting a bit annoyed with your responses lately. Keep it up and you'll have a lot of time to tear things apart! Edited May 12, 2010 by Qman Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 12, 2010 Share Posted May 12, 2010 (edited) The male/female stub thing will swap around. I needed a 4.111 diff for a transmission swap into a '96 legacy and the one I got was a male (90 to 94 5MT diff). Rather than change the axles I dissasembled both diffs and swapped the spider gears - that is I took the 3.9's female style spiders and installed them into the 4.111 diff in place of it's bolt-in male style spider's. Worked just fine. Didn't have to touch any R&P stuff or reshim anything. When you are talking about open diffs only, all the parts seem to match up pretty well over the years. GD Edited May 12, 2010 by GeneralDisorder Quote Link to comment Share on other sites More sharing options...
Uberoo Posted May 13, 2010 Author Share Posted May 13, 2010 ok thank you. Quote Link to comment Share on other sites More sharing options...
