logang1k Posted May 12, 2010 Share Posted May 12, 2010 I stripped out my dash and unplugged a bank of 4 relays(?) and im not sure if I got them plugged back in right. The relays have stayed in the holder, so their order should be right. I just need to know which wire goes to which relay. Link to comment Share on other sites More sharing options...
Gloyale Posted May 12, 2010 Share Posted May 12, 2010 They are for the the following: Heater blower Rear defrost Headlight Left Headlight Right They all use the same relay and the relay will only plug in one way. As long as each connector has a working relay, your fine. Actually that's one of the ways I test relays in these cars. Just switch em round to test wether the circuit has a problem or the relay. Link to comment Share on other sites More sharing options...
logang1k Posted May 12, 2010 Author Share Posted May 12, 2010 I have deleted the heater, and both headlights work so I guess that is not why my turn signals stopped working. Might have left something unplugged. Link to comment Share on other sites More sharing options...
logang1k Posted May 12, 2010 Author Share Posted May 12, 2010 when I deleted the heater I took the vacuum canister thing out from the passenger side strut tower. Is there anything else that feeds off of its vacuum supply? It looks like the push button 4wd works off of it but Im swapping in a D/R 5mt. Link to comment Share on other sites More sharing options...
SubaruDreamer Posted July 29, 2010 Share Posted July 29, 2010 logang1k said: I have deleted the heater, and both hid headlights work so I guess that is not why my turn signals stopped working. Might have left something unplugged. It could be exactly that. Did you check everything was plugged? Link to comment Share on other sites More sharing options...
logang1k Posted July 29, 2010 Author Share Posted July 29, 2010 No hids on this old beast Link to comment Share on other sites More sharing options...
