Just get a used one, they bend and you will never get it back to original. When you bolt the new one up, make sure you do NOT cross thread the 2 rear bolts, they are fine thread and are easy to cross.
Real easy, two bolts in the back, and the pivot bolt up front along with the sway bar bolt and the ball joint.
Huge interchange 90 - 99 at least.
