SoobNoob88 Posted May 19, 2010 Share Posted May 19, 2010 I tried searching but couldn't find quite exactly what I'm looking for but I'm going to look at a flywheel, driveline, and 5 spd d/r out of an 86 gl tomorrow to hopefully swap into my 84 wagon and was wondering if there was anything I can do to check the tranny out before wasting my time. The motor is out of the car at the moment so other than making sure it spins, anything else I can do? Link to comment Share on other sites More sharing options...
idosubaru Posted May 19, 2010 Share Posted May 19, 2010 drain the fluid and check for any chunks, grit or silver shiny stuff. might want to take a pan if you think the guy doesn't want gear oil all over the ground. Link to comment Share on other sites More sharing options...
bratsrus1 Posted May 19, 2010 Share Posted May 19, 2010 Hi This is Jerry, i make a 5 speed kit for your 84 wagon and i can let you know all of the ins and out about installing the 5 speed. Call me 1-509-952-2855 before you buy parts that you don't need. Thanks Jerry Link to comment Share on other sites More sharing options...
SoobNoob88 Posted May 19, 2010 Author Share Posted May 19, 2010 Draining the fluid is a good Idea, I think I can handle that. Jerry, thanks for the help, Ill give you a call when I get outta class today. Link to comment Share on other sites More sharing options...
doobieryan Posted May 28, 2010 Share Posted May 28, 2010 ive talked to jerry, he really is a great help! he knows what hes doing Link to comment Share on other sites More sharing options...
