Scott in Bellingham Posted May 20, 2010 Share Posted May 20, 2010 I make lift kits for legacy and impreza up to 99 , now will that kit fit a Forester, is it all the same underneath just with longer struts?? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 20, 2010 Share Posted May 20, 2010 If it fit's an Impreza, it will probably fit a Forester. The Forester is based on the Imp not the Legacy. GD Link to comment Share on other sites More sharing options...
idosubaru Posted May 20, 2010 Share Posted May 20, 2010 Forester is based off Impreza platform I believe Scott. I would think your kits are almost ready made for the forester. You say up to 1999 - not sure what changes in 2000 but maybe the Forester is more like the later stuff than earlier since it got the Phase II engines/trans, etc. I might look there for differences in the forester. Curious - do you know what differences there are in 2000+ from the 90's? Link to comment Share on other sites More sharing options...
The Korean Posted May 20, 2010 Share Posted May 20, 2010 Not sure if this will help you out Scott, but here is a 01 Forester with 2" strut spacers... 225/70 15's on my 01 Forester. This is with 2" strut blocks but had these tires on before the lift and they worked fine. Slight rub at full lock. Kevin on SF.org made these blocks to straighten out the trailing arm geometry. I'm gonna do this as well because the rear suspension has some bind with the strut blocks on it. Hope this helps. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted May 20, 2010 Author Share Posted May 20, 2010 Forester is based off Impreza platform I believe Scott. I would think your kits are almost ready made for the forester. You say up to 1999 - not sure what changes in 2000 but maybe the Forester is more like the later stuff than earlier since it got the Phase II engines/trans, etc. I might look there for differences in the forester. Curious - do you know what differences there are in 2000+ from the 90's? rear suspension has a different arm setup at least on the legacy anyway , front seems to be the same Link to comment Share on other sites More sharing options...
johnceggleston Posted May 20, 2010 Share Posted May 20, 2010 some one posted a link recently for a 1" lift kit for a legacy. it was designed for the top of the strut and since the outback struts can be used on legacys and imprezas i searched and found the they did indeed list the same lift kit for those other cars. i wish i had bookmarked the site. so i think the answer is yes. but when swapping outback struts in to an impreza, you have to turn? rotate the top hats, i think. that might complicate things but i doubt it. Link to comment Share on other sites More sharing options...
