Old Pearl Posted May 20, 2010 Share Posted May 20, 2010 I recently bought a 1991 legacy AWD wagon that I am trying to bring back to life. The back carpet area over the exhaust caught fire due to the muffler getting too hot. It happened before I bought the car and the story is that it happened while it was idleing. I know this is rare, but has Anyone ever seen this before. Link to comment Share on other sites More sharing options...
Uberoo Posted May 20, 2010 Share Posted May 20, 2010 ive heard of cats getting hot and starting fires,but mufflers?I suppose its possible.where did the heat shielding go? Link to comment Share on other sites More sharing options...
Old Pearl Posted May 20, 2010 Author Share Posted May 20, 2010 Acually the heat shielding is still there. I too have heard of cats getting red hot. It melted the carpet and the padding underneath had to be removed as it was charcoal and smelly. Link to comment Share on other sites More sharing options...
2.5_IMP Posted May 20, 2010 Share Posted May 20, 2010 My 1987 GL had a melted bumper, but it was due to an aftermarket muffler that had been tucked up too close. Link to comment Share on other sites More sharing options...
johnceggleston Posted May 20, 2010 Share Posted May 20, 2010 Acually the heat shielding is still there. I too have heard of cats getting red hot. It melted the carpet and the padding underneath had to be removed as it was charcoal and smelly. was this in the area of the back seat or the rear cargo area?? i cooked the capet i had on the bed of a 90 nissan pickup, damn near killed my dog. the muffler / pipe was boogered and rotten and it was pointed at the bed. new pipes fixed it. Link to comment Share on other sites More sharing options...
MorganM Posted May 20, 2010 Share Posted May 20, 2010 (edited) The muffler on that car doesn't get that hot even sitting there ideling. If the muffler got that hot then the cat would have been WAY hotter (since it's closer to the heat source) I really don't think that carpet back there is going to combust from a muffler that's not only behind a heatshield but also behind other layers of metal and dapening material under the carpet. Before a muffler got hot enough to cause that to happen other parts of the exhaust would have been even hotter and done the same thing elsewhere in the car. I just don't buy the story... unless we are missing some key details? Was there an exhuast leak right there? Was someone under there welding to fix something? Either there's more to the story or the story is bogus because this doesn't add up. Edited May 20, 2010 by MorganM Link to comment Share on other sites More sharing options...
Old Pearl Posted May 20, 2010 Author Share Posted May 20, 2010 That is the story I was told by the PO. The area in front of the cat and behind the cat show no signs of heat damage. The only area showing heat damage is the cargo area carpet, the plastic cover over the spare tire, and part of the mud flap on the driver rear side. I will inspect the muffler for holes (that is a good point) Link to comment Share on other sites More sharing options...
Turbone Posted May 21, 2010 Share Posted May 21, 2010 Is the plastic on the bumper also melted? I ask this because my 89 RX was like what you described. But it was from running the engine so hard and low on oil it eventually threw a rod out the top of the block. But before that happened, it also melted a lot of the plastic in the area around the muffler and inside the rear compartment. The PO may not be telling you the entire story for sure. Link to comment Share on other sites More sharing options...
Qman Posted May 21, 2010 Share Posted May 21, 2010 Yep, I saw it and was shocked as well! Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 21, 2010 Share Posted May 21, 2010 Was this a smokers car? Sounds to me more like someone threw a cigarette out the window, and it came back in and landed on the carpet in the cargo area. I think it would have to be throwing flames out of the muffler to get hot enough to catch the interior of the car on fire. Link to comment Share on other sites More sharing options...
Turbone Posted May 21, 2010 Share Posted May 21, 2010 Kind of difficult to burn the mudflap this way tho. Link to comment Share on other sites More sharing options...
Qman Posted May 21, 2010 Share Posted May 21, 2010 Was this a smokers car? Sounds to me more like someone threw a cigarette out the window, and it came back in and landed on the carpet in the cargo area. I think it would have to be throwing flames out of the muffler to get hot enough to catch the interior of the car on fire. Rob, picture time. Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 21, 2010 Share Posted May 21, 2010 Kind of difficult to burn the mudflap this way tho. I guess we'll go with the flames out of the muffler theory then... Link to comment Share on other sites More sharing options...
Turbone Posted May 21, 2010 Share Posted May 21, 2010 (edited) Rob, picture time. I'll see if I can find some. Shot of the rear bumper after I got the car. Edited May 21, 2010 by Turbone Link to comment Share on other sites More sharing options...
Rooster2 Posted May 21, 2010 Share Posted May 21, 2010 The muffler on that car doesn't get that hot even sitting there ideling. If the muffler got that hot then the cat would have been WAY hotter (since it's closer to the heat source) I really don't think that carpet back there is going to combust from a muffler that's not only behind a heatshield but also behind other layers of metal and dapening material under the carpet. Before a muffler got hot enough to cause that to happen other parts of the exhaust would have been even hotter and done the same thing elsewhere in the car. I just don't buy the story... unless we are missing some key details? Was there an exhuast leak right there? Was someone under there welding to fix something? Either there's more to the story or the story is bogus because this doesn't add up. +1 on your not being told the complete story, or being told a bogus story. Rear mufflers never over heat as described, while the rest of the muffler system is unaffected. Link to comment Share on other sites More sharing options...
bheinen74 Posted May 21, 2010 Share Posted May 21, 2010 if exhaust has break in it, pointing towards something, it can definitely melt, and possibly ignite over time. Once I carried a bike on back of my Acura, and the tire was near the tailpipe. After 900 miles, yeah, it burned the tire to a crisp. Link to comment Share on other sites More sharing options...
