lmdew Posted May 21, 2010 Share Posted May 21, 2010 I can't find the FWD Fuse holder, its not on the passenger side like the older Legacy's. Did they do away with this option for the Auto Transmissions on the 2000? I put a transmission in a while back for a fellow and it makes a harsh popping sound when you go from rev to Drive, it sounds like it coming from the rear diff. The gear ratios are the same, the drive shaft U-joints look good. 330,000 miles on the car. I wanted to try putting it in FWD to eliminate the rear drive shaft and diff. Link to comment Share on other sites More sharing options...
oldgray1 Posted May 21, 2010 Share Posted May 21, 2010 I have a 2001 H6 LLBean and the FWD fuse slot is in the under hood fuse box. The fuse box is on the left in these models. Link to comment Share on other sites More sharing options...
lmdew Posted May 23, 2010 Author Share Posted May 23, 2010 Thanks, yep it was there. FWD light on the dash after the fuse was installed. Thanks Link to comment Share on other sites More sharing options...
