ratchet Posted May 23, 2010 Share Posted May 23, 2010 I'm trying to decide whether to install the 2010 Forester stock block heater now, while the engine is like two months old or install a circulating tank heater between now and November. If memory serves me correctly, it appeared there was about 4" between the install location (plug) and the top of the header. I've read that even on newer engines the plug can be a real bear. My question is will the allen fitting and my cheater bar have enough room without lowering the header? There also is the consideration that I'll lose leverage with the universal at the end of my bar (it'll definitely be on an angle) if everything does fit. Thank You! Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 23, 2010 Share Posted May 23, 2010 Seems to me like it would be easier to get one of those ones that goes in the lower radiator hose. If you're dead set on the screw in type, it's 5 bolts to lower the manifold for extra room, and about $6 for two new gaskets. Link to comment Share on other sites More sharing options...
ratchet Posted May 23, 2010 Author Share Posted May 23, 2010 Seems to me like it would be easier to get one of those ones that goes in the lower radiator hose. If you're dead set on the screw in type, it's 5 bolts to lower the manifold for extra room, and about $6 for two new gaskets. Most certainly not dead set. In fact I kind of prefer the tank/circulating kind just because they actually do a better job. Link to comment Share on other sites More sharing options...
