kybishop Posted May 24, 2010 Share Posted May 24, 2010 My 1986 GL wagon sometime has a smell of gas fumes around the back where the tank is, usually after driving. I crawled under and did not see any wet spots or anything obvious. Before I go tearing into it too much, taking the tank down and all...is there a weak link or typical area where these develope leaks? Thanks, KB Link to comment Share on other sites More sharing options...
Subarule Posted May 24, 2010 Share Posted May 24, 2010 Fresh gas or exhausted gas fumes? Link to comment Share on other sites More sharing options...
kybishop Posted May 24, 2010 Author Share Posted May 24, 2010 Fresh gas. I need to check up around the fuel filter better for starters. I was wondering if there was a common place where these could develop leaks. Thanks. Link to comment Share on other sites More sharing options...
Yo'J Posted May 26, 2010 Share Posted May 26, 2010 I'd stick my head up there and look for leaks while running, it might show itself. You say back of the car? Do they salt the roads there? Germany, MI. Wa. Il. Ky? Frankforts everywhere! Link to comment Share on other sites More sharing options...
eVIL_NTT Posted May 26, 2010 Share Posted May 26, 2010 I think there may be an evap tank back there to check as well. I had the same gas fume smell and that was the culprit. Link to comment Share on other sites More sharing options...
DaveAP Posted May 26, 2010 Share Posted May 26, 2010 My '78 brat had that problem. I noticed a wet spot in the bottom of the rear quarter fender. I opened the panel and could see a small tube wet with gas. I just allowed it to vent to the outside. Probably not the professional way, but the smell went away. dp Link to comment Share on other sites More sharing options...
94Loyale Posted May 27, 2010 Share Posted May 27, 2010 Also, check and make sure your fill tube isn't rotted. I had that on two of my Loyales. Link to comment Share on other sites More sharing options...
kybishop Posted May 27, 2010 Author Share Posted May 27, 2010 Thanks everyone. That gives me several things I need to check and great information. I do appreciate it. It is Frankfort Kentucky, bourbon capital of the world. And yes, they do salt the roads. The fill tube looked good but will give it all closer inspection. My vent tube on my old 78 Ramcharger was the culprit for the smell of fresh fumes on it. Link to comment Share on other sites More sharing options...
