mcbrat Posted February 17, 2004 Share Posted February 17, 2004 have a leaking injector on 84 turbo brat.... will an ea82 MPFI injector work? I don't think there are any at my local JY though..... Link to comment Share on other sites More sharing options...
carfreak85 Posted February 17, 2004 Share Posted February 17, 2004 I asked about injectors a long time ago and the consensus was that EA82T and EA81T injectors are identical. I wouldn't go with MPFI just because they are lower flowing... probably Link to comment Share on other sites More sharing options...
Stupidru Posted February 17, 2004 Share Posted February 17, 2004 Mick, A regular non-turbo xt has same injectors, I believe their is a few more applications, but I can't remember which ones. Go to partsamerica.com & cross part #'s. Subaru still has them in-stock but there really expensive, if I remember correctly they were like, $125ish. If you have trouble finding some, I know of an old NA XT in a friends JY, but I'd have to pull it myself. That I will not do until weather breaks. These injectors are (all-in-one) the hoses are permanently connected to the injector & its a PITA to get hoses off the fuel rail being careful not to slit hose. BTW whats wrong with your injectors? Jay Link to comment Share on other sites More sharing options...
ShawnW Posted February 17, 2004 Share Posted February 17, 2004 I mailed him an injector today. Link to comment Share on other sites More sharing options...
mcbrat Posted February 17, 2004 Author Share Posted February 17, 2004 it's leaking badly between the permanently attached hose and the injector. Link to comment Share on other sites More sharing options...
mcbrat Posted February 22, 2004 Author Share Posted February 22, 2004 okay, got the injectors off the turbo brat, and they are a higher flowing injector than what Shawn sent me. look identical, except the nozzle on mine is black with a larger opening, and Shawns were white w/small opening. also, on mine, the small hose piece was not an integral part of the injector. the injector has a normal barbed fitting on it. my hose just appears to have been bad, plus the holder was broken and the rubber ring around the injector was torn. Link to comment Share on other sites More sharing options...
baccaruda Posted February 22, 2004 Share Posted February 22, 2004 how are the spfi injectors? a friend has a complaint about performance with his car and i'm going to help him shoot it. Link to comment Share on other sites More sharing options...
calebz Posted February 22, 2004 Share Posted February 22, 2004 Originally posted by baccaruda how are the spfi injectors? a friend has a complaint about performance with his car and i'm going to help him shoot it. SPFI is a completely different beast. only one injector, and its mounted inside the throttle body Link to comment Share on other sites More sharing options...
baccaruda Posted February 22, 2004 Share Posted February 22, 2004 aaah. so he needs to go to pull n save and dissect an SPFI throttle body. thanks Link to comment Share on other sites More sharing options...
mcbrat Posted February 23, 2004 Author Share Posted February 23, 2004 pics. here's the broken holder..... and the barbed inlet for the injector.... and comparing mine (black) to a normal ea81T injector (I Think) Link to comment Share on other sites More sharing options...
Stupidru Posted February 23, 2004 Share Posted February 23, 2004 I have the white in my ea81t, Man...no wonder your having fuel issues Mick. These turbo pushrod engines are totally different beasts, ya know? Link to comment Share on other sites More sharing options...
mcbrat Posted February 23, 2004 Author Share Posted February 23, 2004 yeah I was thinking the same thing.... (fuel consumption) Link to comment Share on other sites More sharing options...
GLCraig Posted February 23, 2004 Share Posted February 23, 2004 from what i've read about Bosch injectors, it's really the color of the top of the injectors that identifies the flow rate. Then again maybe I missread the article. Link to comment Share on other sites More sharing options...
mcbrat Posted February 23, 2004 Author Share Posted February 23, 2004 rats! I got everything back together, and it appears the injector must have an internal crack, so looks like I'm gonna need a black tip injector.... Link to comment Share on other sites More sharing options...
mcbrat Posted February 23, 2004 Author Share Posted February 23, 2004 one more odd thing... when I was trying to start it, it at first acted like it lost compression through the injector hole too.... hmmm. could it be "blowing" the fuel back through the port so it looks like a leaking injector? I would think then that it wouldn't be firing on that cyl, but it doesn't seem to be missing..... hmmmm...... Link to comment Share on other sites More sharing options...
Stupidru Posted February 23, 2004 Share Posted February 23, 2004 There is an o-ring in the fuel port on the head, could that be dry rotted? Subaru still has the o-rings in stock. Link to comment Share on other sites More sharing options...
mcbrat Posted February 24, 2004 Author Share Posted February 24, 2004 I'll be checking that as well..... Link to comment Share on other sites More sharing options...
mcbrat Posted February 24, 2004 Author Share Posted February 24, 2004 thanks to Skip for some info. has led me to this, but still researching.... the one on the left is a RX7 injector, the one on the right, a Z car... http://images.cardomain.com/member_images/7/web/403000-403999/403158_41_full.jpg also found on another site: "Repaired fuel leak under maniford (injector o-rings). new injector o-rings, injector grommets, injector seals" Link to comment Share on other sites More sharing options...
Meeky Moose Posted February 24, 2004 Share Posted February 24, 2004 so does that mean ya need my 4 injectors? lol Link to comment Share on other sites More sharing options...
mcbrat Posted February 25, 2004 Author Share Posted February 25, 2004 I'm gonna pick up new O rings tomorrow hopefully, but not sure when I will get to it, as I'm trying to get some stuff done on my red brat first.... Link to comment Share on other sites More sharing options...
mcbrat Posted February 27, 2004 Author Share Posted February 27, 2004 seal kits should be in Friday. I got a chance to watch it today while it was running, and I could actually see the fuel coming up from the bottom side of the injector.... Link to comment Share on other sites More sharing options...
mcbrat Posted March 5, 2004 Author Share Posted March 5, 2004 finally done! after the posts here, and more research, and such, as Craig mentioned, the color of the tops identifies the flow rate, and the tops are identical to the injectors I got from shawn. my pics I took were blurry, but upon closer inspection, it looks like the pintles are the same size, just the hole in the little cap thats bigger. so I put in one of Shawns injectors with the new seals, and all is well. I also took the chance to clean/check the plugs, and put some new Accel wires on. took it out for a spin. runs good, and no fuel smell!!! yay! Link to comment Share on other sites More sharing options...
