SchwarzeEwigkt Posted May 28, 2010 Share Posted May 28, 2010 I've been all over the Internet and back and climbed all over my car trying to figure out its build date. I can't find it anywhere. I haven't needed it up until now, but I blew a hole in the radiator the other day and need to know the build date to order another one. I looked at the aluminum stamped plate under the hood on the driver strut tower and the sticker inside the driver door on the body. Nothing on either. I haven't found any other stickers anywhere besides the ones on various parts with the VIN on it. Where am I not looking? This has got me pretty steamed since I want to fix the bloody thing and I don't know which radiator to order. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 28, 2010 Share Posted May 28, 2010 It's on the aluminum tag under the hood. It only says the month and year. Just stop looking so hard and you'll find it. Quote Link to comment Share on other sites More sharing options...
2.5GL Posted May 28, 2010 Share Posted May 28, 2010 In many cases, the last eight digits of the VIN will suffice. If you are going after market, call your local/nearest subaru dealer, give them the last 8 of your VIN and they will be able to tell you. Then you can tell whoever the month and year... Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted May 28, 2010 Share Posted May 28, 2010 they used to put a sticker on the b-pillar, the door column. but they stopped doing that in 96 or 97. i assume since you cannot find the sticker with the build date that you have a 97 or later. it is now located on the bottom of the driver door. you have to get on the ground to see it and if you wear reading glasses they may not be strong enough. my nose ends up being very close to the sticker. Quote Link to comment Share on other sites More sharing options...
heartless Posted May 28, 2010 Share Posted May 28, 2010 they used to put a sticker on the b-pillar, the door column. but they stopped doing that in 96 or 97. i assume since you cannot find the sticker with the build date that you have a 97 or later. it is now located on the bottom of the driver door. you have to get on the ground to see it and if you wear reading glasses they may not be strong enough. my nose ends up being very close to the sticker. Why on earth would they put it on the BOTTOM of the door?????? That is just plain ridiculous! :-\ Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted May 28, 2010 Share Posted May 28, 2010 Why on earth would they put it on the BOTTOM of the door?????? That is just plain ridiculous! :-\ i think there was a rash of sticker thefts which were then being put on old gen subarus so they could be sold to unsuspecting buyers as 1998 brats. Quote Link to comment Share on other sites More sharing options...
Durania Posted May 28, 2010 Share Posted May 28, 2010 Build date and year on every Subaru I've had is on the VIN plate on the driver's side door jamb. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted May 28, 2010 Share Posted May 28, 2010 Build date and year on every Subaru I've had is on the VIN plate on the driver's side door jamb. true up through 95 or 96, at least for legos. Quote Link to comment Share on other sites More sharing options...
Durania Posted May 28, 2010 Share Posted May 28, 2010 true up through 95 or 96, at least for legos. Ahh. Only Legacy I have owned is a 91. All my other experience is with BRATS and Imprezas. Quote Link to comment Share on other sites More sharing options...
SchwarzeEwigkt Posted May 28, 2010 Author Share Posted May 28, 2010 Yeah, mine's a '97. I'll look on the bottom of the door in a bit. It's definitely not on the metal plate on the strut tower. Just VIN, configuration codes and such. Incidentally, it just occurred to me that I might be able to fix the radiator by soldering it. Gunna look that up. I figure if I make the hole worse, who cares? Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted May 28, 2010 Share Posted May 28, 2010 Yeah, mine's a '97. I'll look on the bottom of the door in a bit. It's definitely not on the metal plate on the strut tower. Just VIN, configuration codes and such. Incidentally, it just occurred to me that I might be able to fix the radiator by soldering it. Gunna look that up. I figure if I make the hole worse, who cares? If you can solder it, then I would suggest using JB Weld. It is an epoxy that sets up rock hard. The trick is to have a very clean surface, and wait 12 hours before using after applying. I have used it successfully to seal up a leak in metal tubing on high pressure A/C line. Quote Link to comment Share on other sites More sharing options...
Qman Posted May 28, 2010 Share Posted May 28, 2010 i think there was a rash of sticker thefts which were then being put on old gen subarus so they could be sold to unsuspecting buyers as 1998 brats. Oh good lord, and it isn't even April Fools Day... Quote Link to comment Share on other sites More sharing options...
SchwarzeEwigkt Posted May 28, 2010 Author Share Posted May 28, 2010 If you can solder it, then I would suggest using JB Weld. It is an epoxy that sets up rock hard. The trick is to have a very clean surface, and wait 12 hours before using after applying. I have used it successfully to seal up a leak in metal tubing on high pressure A/C line. Good idea. I was planning to get some to plug a hole in my exhaust anyway. What the heck, you know? Incidentally, I looked under the door. Nothing but another VIN sticker. I'm starting to think they didn't put that ANYWHERE on the car. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 28, 2010 Share Posted May 28, 2010 Good idea. I was planning to get some to plug a hole in my exhaust anyway. What the heck, you know? Incidentally, I looked under the door. Nothing but another VIN sticker. I'm starting to think they didn't put that ANYWHERE on the car. Build date ABSOLUTELY is on the sticker on teh bottom of the door. Look for anything that looks like a date. It won't say "build date" It's simply more like "04/97" Not in the door frame, actually on the lower edge of the door. date Should be in the corner Quote Link to comment Share on other sites More sharing options...
SchwarzeEwigkt Posted May 28, 2010 Author Share Posted May 28, 2010 Build date ABSOLUTELY is on the sticker on teh bottom of the door. Look for anything that looks like a date. It won't say "build date" It's simply more like "04/97" Not in the door frame, actually on the lower edge of the door. date Should be in the corner Well, I'll look again. I was planning to go out in the other car to get some JB Weld for the radiator anyway. Quote Link to comment Share on other sites More sharing options...
SchwarzeEwigkt Posted May 28, 2010 Author Share Posted May 28, 2010 Looked again. There's nothing on the door itself other than the VIN sticker. Do you mean on the sticker on the door jamb that has the tire pressures on it? I didn't see it there, though that's where I expected to find it. Quote Link to comment Share on other sites More sharing options...
SchwarzeEwigkt Posted May 29, 2010 Author Share Posted May 29, 2010 (edited) Used the fallback plan and called the local dealer. Seems it was built in 8/96. So it uses the more expensive radiator. Nuts. Oh well. Edited May 29, 2010 by SchwarzeEwigkt Eye kan spel gud. Quote Link to comment Share on other sites More sharing options...
SchwarzeEwigkt Posted May 29, 2010 Author Share Posted May 29, 2010 Ordered another radiator. Found what seems to be a very good parts place, too. www.rockauto.com. Cheap, rates well. Picked up a few other things for the other cars too. Whoo, $5 foglight assemblies for the fiance's Focus! Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 29, 2010 Share Posted May 29, 2010 I've used Rockauto a number of times and have always been completely satisfied. Low prices, shipping can be a bear if you order a lot of stuff (some parts coming from different warehouses they charge shipping for each shipment) but most of the time it's still cheaper and better parts than what you get at the local Autozone or whatever, and they ship out fast. Every now and then you find closeout deals on some parts. I got a Beck Arnley clutch kit for my truck, normally a $150 kit, for $50 with shipping. Quote Link to comment Share on other sites More sharing options...
SchwarzeEwigkt Posted May 30, 2010 Author Share Posted May 30, 2010 I took advantage of that, in fact! I got a set of front brake rotors for my BMW on closeout for $15 each. That's like a third what I was expecting them to cost. I figure if they suck, I'll get better ones and sell these ones for scrap. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 30, 2010 Share Posted May 30, 2010 Looked again. There's nothing on the door itself other than the VIN sticker. It's on that sticker. I swear. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 2, 2010 Share Posted June 2, 2010 My date is on my 95 Legacy I can't remember off hand but it was sometime around late 94 of I remember right. Quote Link to comment Share on other sites More sharing options...
