Well. A nice chain of events may have ruined my axle seal in the front. Im not sure of the correct name of this seal, the one on the transmission(transaxle?) side. I had my strut on the passenger side brake into two pieces (pics will be up tomorrow) While replacing it the strut pushed on the spindle and pulled th cv axle out. And now I have a leak. We put the axle back in and it slid in nice and easy. No idea how it could have ruined the seal.
So, anyone got a part number for the seal, where I could get it or even the correct name? Oh I also had the brake bleeder brake off on my new caliper...thank god for lifetime warranties.
You shouldn't be leaking ATF as the front diff is sealed from the transmission. It's supposed to be 80w90 gear oil. If it's coming out red someone has added the wrong fluid to the differential at some point.
What you need is probably called a differential oil seal or diff axle seal at a local parts store.
Or a wheel seal, like gary said:
http://www.autozone.com/autozone/catalog/parts/partsShelf.jsp?categoryDisplayName=Drivetrain&fromType=parts&fromString=search&parentId=12-0&currentPage=1&filterByKeyWord=wheel+seal&isSearchByPartNumber=false&navValue=11200256&categoryNValue=11299999&fromWhere=&itemId=256-0&displayName=Wheel+Seal+-+Front&searchText=wheel+seal
Edited by Fairtax4me
Passenger Side: Subaru P/N 806730031
http://www.subarupartsforyou.com/cp_partdetail.php?partid=15394
Driver Side: Subaru P/N 806730032
http://www.subarupartsforyou.com/cp_partdetail.php?partid=15395
Looks like items 5 and 17 here:
http://opposedforces.com/parts/legacy/us_b11/type_45/train/differential_transmission/
Edited by Mike104
crisis averted. When we were doing this job it was getting dark out last night. Got under their this morning to find that the cv axle hadnt seated all the way. Now I just gotta go get a caliper and some fluids.
Those heat shields on the exhaust sure can hold alot of fluid too! Was worried the car might catch on fire. And yet another heatshield is falling off now.
Thanks for the info, good to know for if I ever have to do the seals (I probably will seeing as I dont plan on parting with the car)
