I believe the tricky part is the 1.25 pitch.
I wanna say 14 x 1.25 from memory (a bad memory).
Take one of the nuts you took off to Lowes. Figure out how long of bolts you'll need.
Usually you need 2 nuts(and 4 washers) and 2 bolts to put an engine on the stand. The 2 lower studs remain in the engine unless you purposely remove them.
BTW engine/trans nuts, motor mount nuts, and exhaust stud nuts are all the same. Come with some special coating from Subaru and are a bit pricey.
I ALWAYS put anti-seize on the new bolts that will thread into the engine. Don't need to be buggering up those threads. I actually also apply some to the stud threads.
