zzGUY46 Posted June 2, 2010 Share Posted June 2, 2010 I have a 1996 2.2L, AT, engine. I want to put it on an engine stand. What size bolts do I need? Link to comment Share on other sites More sharing options...
davebugs Posted June 2, 2010 Share Posted June 2, 2010 I believe the tricky part is the 1.25 pitch. I wanna say 14 x 1.25 from memory (a bad memory). Take one of the nuts you took off to Lowes. Figure out how long of bolts you'll need. Usually you need 2 nuts(and 4 washers) and 2 bolts to put an engine on the stand. The 2 lower studs remain in the engine unless you purposely remove them. BTW engine/trans nuts, motor mount nuts, and exhaust stud nuts are all the same. Come with some special coating from Subaru and are a bit pricey. I ALWAYS put anti-seize on the new bolts that will thread into the engine. Don't need to be buggering up those threads. I actually also apply some to the stud threads. Link to comment Share on other sites More sharing options...
zzGUY46 Posted June 2, 2010 Author Share Posted June 2, 2010 I bought the engine already out of the car, don't have the nuts. ( Luckly I still have 2 in the sac) I may have some exhaust nuts, give look see. Thanx for the help. Link to comment Share on other sites More sharing options...
zzGUY46 Posted June 3, 2010 Author Share Posted June 3, 2010 Well, I went to my local True Value and did the trial and error. My engine was in my pickup. Its a 10 x1.25. I got em about 4" long. Thanx again for the help. Link to comment Share on other sites More sharing options...
