Roger Stokes Posted June 3, 2010 Share Posted June 3, 2010 I think this question has been answered, I just couldn`t find it. So my separater plate on my 2001 forester has 70,000 miles on it and is not leaking. Whats your advice?. change it? or let it go? Thanks Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 3, 2010 Share Posted June 3, 2010 I thought models higher then 1996 already had stamped metal separator plates? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 3, 2010 Share Posted June 3, 2010 They should have the aluminum plate, but that doesn't mean it can't start leaking. There's a reason they changed the design... again. Not sure exactly what it is though. I'd at least remove it and reseal it for good measure if you have the engine out. Use Ultra Grey or Anaerobic gasket maker. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 3, 2010 Share Posted June 3, 2010 It's like '99 before they fixed the plastic plate problem. I just replaced a leaking plastic plate on a '98 OBS. If it's metal and not leaking I wouldn't touch it. If it's plastic for some reason then replace it for sure. GD Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 3, 2010 Share Posted June 3, 2010 I thought models higher then 1996 already had stamped metal separator plates?nah, i think nearly every EJ25 i've pulled has the plastic. did a 97 yesterday, plastic. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 3, 2010 Share Posted June 3, 2010 Ahh I see mine is plastic on the 95 and leaking I picked up a plate from the dealer months ago, going to do the clutch and everything in one shot.. seems like it was ok to replace the clutch but not the TOB at the same time. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 3, 2010 Share Posted June 3, 2010 seems like it was ok to replace the clutch but not the TOB at the same time.boo for that. replace the TOB, pilot bearing, and both clutch clips with every clutch job. the clips are the same across tons of models so usually they have them in stock. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 3, 2010 Share Posted June 3, 2010 boo for that. replace the TOB, pilot bearing, and both clutch clips with every clutch job. the clips are the same across tons of models so usually they have them in stock. I wont complain too much I got the car for $400 with 195K on it besides pulling the motor lets me get to the other goodies that need to be replaced. Quote Link to comment Share on other sites More sharing options...
