As long as they are throttle body injection heads, yes. Turbo and MPFI heads are dual-port and are not interchangeable because the SPFI and Carb manifolds are single-port.
SPFI heads will not have the ports for Air Injection drilled out on the bottom near the exhaust port. Those would have to be drilled or the AIS removed (may not be possible for emissions reasons in your area) for them to work on a carbed engine.
