Roger Stokes Posted June 4, 2010 Share Posted June 4, 2010 (edited) I`m replaceing all the seals befor I put the engine back in the car. I understand there is a O ring with the seal on the oil pump shaft. Can the O ring be replaced from the from the seal side? or does the shaft have to be pulled from the inside, oil pan? If so is it nessary to replace? I`m haveing my Nissan mec. change everything out for me I`m just getting all the information befor I order all the parts. It`s a 2001 forester. Thanks, Roger Edited June 4, 2010 by Roger Stokes wrong one Link to comment Share on other sites More sharing options...
Roger Stokes Posted June 4, 2010 Author Share Posted June 4, 2010 I`m replaceing all the seals befor I put the engine back in the car. I understand there is a O ring with the seal on the oil pump shaft. Can the O ring be replaced from the from the seal side? or does the shaft have to be pulled from the inside, oil pan? If so is it nessary to replace? I`m haveing my Nissan mec. change everything out for me I`m just getting all the information befor I order all the parts. It`s a 2001 forester Thanks, Roger Link to comment Share on other sites More sharing options...
wtdash Posted June 4, 2010 Share Posted June 4, 2010 (edited) The O-ring is on the lower part of the block behind the oil pump....Check out the Beer Garage....worked for me. GL, Td Edited June 4, 2010 by wtdash clarify location Link to comment Share on other sites More sharing options...
Mike104 Posted June 4, 2010 Share Posted June 4, 2010 Its the blue O-ring in this picture. Need to remove the Oil Pump first. Will make it easier to change the front crankshaft seal too. Link to comment Share on other sites More sharing options...
