brighton98 Posted June 4, 2010 Share Posted June 4, 2010 My 95 Legacy has cold A/C, vent temp 45F, 26/215 pressures. At initial startup it always works, but when I shut the car then turn A/C on, it sometimes won't kick on; if I turn the button or switch off and on several times, it usually kicks in. I've swapped relays, to no avail--ideas?? Thanks. Link to comment Share on other sites More sharing options...
cobcob Posted June 4, 2010 Share Posted June 4, 2010 Check the fitment of the relay in the socket. Our 2000 OBK had the same issue and it wound up being a bad connection in the relay socket. I spread the pins on the relay and haven't had any issues since. Link to comment Share on other sites More sharing options...
