There are surprisingly few posts on this forum concerning rust repair. I just repaired 7 spots on my roof and the bottom of three doors on my '95 Subaru.
My technique is as follows:
1. Grind off paint and rust with the 3M black wheel for drills.
2. Naval jelly
3. Rust converter [Dupli color spray can]
4. Precoat spray can- 2 coats
5. Touch up spray can-4 coats [Automotivetouchup]
6. Lacquer
If there is penetration, then I cut out enough so that I can get behind the panel with Navel jelly and Rust converter. I find that if there's penetration and I don't get behind the panel, then failure is certain. Of course, this is followed by fiberglass, Bondo, and then steps 4-6.
I think that this works most of the time, but there are still failures. Any comments or different ways of doing it. If there is only surface rust. I appreciate that only steps 4-6 are required, but with a 15 year old car, there is often deep rust by the time the paint bubbles.
I take the rust down to the metal if possible. I talked to a paint supplier that deal with custom mixes for any car. They give out great advice http://www.paintscratch.com/
They agreed that the Dupli-color rust converter is an excelant product.
I take it down as far as i can. I spray three coats as per instructions, and let it sit for 24 hours before I apply any bondo.
When Blu had his rust i gournd down all the rust and left a good size hole. I use the Rust converter, filled the hole, then painted with three cots of Dupli-color primer, wet sand, 4 coats of paint with wet sanding, then 2 coats of top coat, with wet sanding.
Blu was easy :) His hole was under the vinyl body tape so I did not have to paint aside from primer.
On the Justy i look for natural body panel breaks to sand and paint to.
nipper
nipper
