mikec03 Posted June 6, 2010 Share Posted June 6, 2010 There are surprisingly few posts on this forum concerning rust repair. I just repaired 7 spots on my roof and the bottom of three doors on my '95 Subaru. My technique is as follows: 1. Grind off paint and rust with the 3M black wheel for drills. 2. Naval jelly 3. Rust converter [Dupli color spray can] 4. Precoat spray can- 2 coats 5. Touch up spray can-4 coats [Automotivetouchup] 6. Lacquer If there is penetration, then I cut out enough so that I can get behind the panel with Navel jelly and Rust converter. I find that if there's penetration and I don't get behind the panel, then failure is certain. Of course, this is followed by fiberglass, Bondo, and then steps 4-6. I think that this works most of the time, but there are still failures. Any comments or different ways of doing it. If there is only surface rust. I appreciate that only steps 4-6 are required, but with a 15 year old car, there is often deep rust by the time the paint bubbles. Link to comment Share on other sites More sharing options...
Legacy777 Posted June 6, 2010 Share Posted June 6, 2010 Good post and comments. I think you'll see more comments about rust repair in the old gen forum and some in the shop talk forum. Link to comment Share on other sites More sharing options...
nipper Posted June 7, 2010 Share Posted June 7, 2010 I take the rust down to the metal if possible. I talked to a paint supplier that deal with custom mixes for any car. They give out great advice http://www.paintscratch.com/ They agreed that the Dupli-color rust converter is an excelant product. I take it down as far as i can. I spray three coats as per instructions, and let it sit for 24 hours before I apply any bondo. When Blu had his rust i gournd down all the rust and left a good size hole. I use the Rust converter, filled the hole, then painted with three cots of Dupli-color primer, wet sand, 4 coats of paint with wet sanding, then 2 coats of top coat, with wet sanding. Blu was easy His hole was under the vinyl body tape so I did not have to paint aside from primer. On the Justy i look for natural body panel breaks to sand and paint to. nipper nipper Link to comment Share on other sites More sharing options...
