RedRum Posted June 6, 2010 Share Posted June 6, 2010 I actually have 3 subaru's that I about to replace plugs on. 1) 99 Legacy GT 160K miles 2) 01 Legacy L 155K miles 3) 05 Saabaru 9-2x Linear (Impreza 2.5) 103K miles What plugs do you guys recommend using? Also, how often should I do plug wires and what should I get for wires? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 6, 2010 Share Posted June 6, 2010 NGK plugs, and wires from the dealer. Depending on if the engine is a turbo or not - I would replace them at every 60k service interval. More often on the Turbo's - they don't like large plug gaps. GD Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted June 6, 2010 Share Posted June 6, 2010 For plugs, most here will recommend the OEM NGK plugs, you don't have to get them at the dealer, but don't fall for the gimmicks of super fancy Bosch plugs. For the wires, many will say that OEM are the only way to go, but if you get a good quality aftermarket set you should be OK. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted June 6, 2010 Share Posted June 6, 2010 I have had good luck with Bosch wires and Bosch Platinum plugs. Don't recommend chain auto store cheapie house brand wires. They will give you trouble. Quote Link to comment Share on other sites More sharing options...
RedRum Posted June 6, 2010 Author Share Posted June 6, 2010 non-turbo. I got NGK from the dealer for the saabaru. I want to do the 2 legacy's this afternoon and the dealer is closed. Will Advance or Autozone carry the right NGK plugs for a legacy? Platinum? Quote Link to comment Share on other sites More sharing options...
wally Posted June 6, 2010 Share Posted June 6, 2010 ngk plugs, but i've been using STI wires for about 200K miles. Quote Link to comment Share on other sites More sharing options...
RedRum Posted June 7, 2010 Author Share Posted June 7, 2010 So I changed the plugs. 1 of them had a bunch of oil on the plug connector. Is that bad? What can cause this? Quote Link to comment Share on other sites More sharing options...
trapper.john Posted September 12, 2010 Share Posted September 12, 2010 So I changed the plugs. 1 of them had a bunch of oil on the plug connector. Is that bad? What can cause this? I had the same issue with my outback. i then changed the spk plug grommets, and valve cover gaskets and that solved the oil on the plug wires. I was told that is a fairly common thing to have to change after time. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 12, 2010 Share Posted September 12, 2010 Old thread - but I'll give it a pass since it's close to the 90 day window. It's common on all engines that have plug wells in the center of the valve cover's. Honda's and Mitsubishi's do this all the time. I've replaced them on lots of cars. It's a pretty standard deal. GD Quote Link to comment Share on other sites More sharing options...
