MAF Dead?
Hi everyone, I am just trying to verify my findings on my MAF sensor this is on my 94 Loyale SPFI. I read through the manual and did the testing. I got 12.5+ volts when I tested the power lead and I got almost 10 Ohms resistance when I checked the ground connection these were both checked using body ground and then when I checked the voltage between the signal wire and ground I got 0.00V so I'm assuming this is why I have the code for MAF blinking at me I just want to verify that it is the MAF sensor and not a wiring issue as the tests are done with the harness connected to the MAF sensor. The harness connectors are tight and really shiny clean so don't think it is at the connection. Is there any way to test the sensor itself disconnected or is that pretty much the same as what I've already done. Thanks.
