'91 Legacy Rack-n-Pinion seal replacement
My Leg leaks fluid like it has a 24hr stomach virus. I pulled the rack and it needs a seal replacement. Instead of forking out 200-300 for a refurb rack... I would like to try a seal replacement first. I did a general search on the board and found no record of such being posted. Has anyone tried a rack seal replacement? And, if not, could someone offer a point in the right direction?
Thanks for any feedback.
-sp-
if that is not the problem, rather than replacing the seals, i would suggest a used rack. they hardly ever fail and you can pick a good one up for 50$ - 60$, less from a member of the board. i bet mike, mdjdc, has one..
but since they fail so rarely, i bet the o-ring will fix it.
