EA82 Carbed will it run without the computer?
Yeah, if you already removed the feedback carb and replaced it with a weber, then the computer is doing nothing anyway. I belive the fuel pump controller is a separate module from the ECU, it was on the non-feedback EA82's.
Put an old sparkplug in the bung where the 02 sensor was.
The EA82 feedback computer directly controls the fuel pump relay - they do not have a seperate FPCU like the EA81 feedback system. You will have to rewire that either directly to power or through a fuel pump control unit like the non-feedback's or EA81's (EA81 feedback FPCU is the easy choice since it does not control choke power).
