Markus56 Posted June 10, 2010 Share Posted June 10, 2010 Whats the biggest tire on a 14" rim that you could put on a 1st gen legacy? I've been looking at other member's rigs, and it looks like a 205/75/R14 could fit... any comments appreciated! Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted June 10, 2010 Share Posted June 10, 2010 Whats the biggest tire on a 14" rim that you could put on a 1st gen legacy? I've been looking at other member's rigs, and it looks like a 205/75/R14 could fit... any comments appreciated! it will lift your car over 1/2 inch. the top of that tire, 205/75/14, will be more than 1/2 inch taller / closer to the strut spring perch than the stock tire, 185/70/14. that's a lot. put your finger up there and see if you have that much room. i doubt you do. Quote Link to comment Share on other sites More sharing options...
lone500 Posted June 11, 2010 Share Posted June 11, 2010 you might be able to get away with 205/75/14s but i would really only go up to a 195/75/14. been thinking of changing tire sizing myself on my legacy Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted June 11, 2010 Share Posted June 11, 2010 My suggestion is to go with 195X75X14. It will be a little taller, without running the risk of rubbing front wheels when turning and hitting a bump at the same time. Quote Link to comment Share on other sites More sharing options...
