radiator electric fan
The system is really simple.There is no relay,just a Thermo Switch on the radiator.It's a two wire,screw in type switch that is in one of the bungs on the passenger side radiator tank.
When the coolant reached a certain temp,the switch closes and the fan comes on.
If your fan isn't working,aside from checking the wire condition and the grounds,take a look at that switch.
There is a test proceedure for the switch,I don't know what it is.
