JWX Posted February 18, 2004 Share Posted February 18, 2004 I was reading over on the ausubaru board and they mention something about using the hyd lifter cam with soild lifters and it "screams". so what up with this anybody lookeds in to this? is this what people are talking about when they say "the brat cam"? Link to comment Share on other sites More sharing options...
The Scooby Posted February 18, 2004 Share Posted February 18, 2004 i dont think you want to do this, hydraulic lifters are there to make the engine quiter, solid lifters are just that, solid, and beacuase of that there is no cusion between the parts so it tapps and needs to be ajusted frequently. hydraulic lifters have a spring inside that compress and depress against the rods so there is no space in the system, makes it quiter. now, if you are to run solids instead of hydraulics, there will be no difference in the engine, if you want the engine to "scream" then mock up some roller rockers. that will make ti rev faster at higher RPM. Shean Link to comment Share on other sites More sharing options...
JWX Posted February 20, 2004 Author Share Posted February 20, 2004 bump Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 20, 2004 Share Posted February 20, 2004 Scooby - he's talking about EA81's - and yes, the cams are different. It does make sense in a way - the hydro lifters cushion the valve train, and thus the hydro lifter cam has to have a taller profile in order to get the same lift. You would also want the hydro lifter heads as they have bigger valves. And if your going to go to all the work of tearing the thing down to put in a cam, then the $80 that a custom delta cam costs is a better idea in my opinion than trying to locate a hydro lifter cam.... besides with a Delta cam you can USE the hydro lifters and avoid the pain of having to adjust your valves every 30k. GD Link to comment Share on other sites More sharing options...
JWX Posted February 21, 2004 Author Share Posted February 21, 2004 anybody have the specs on both of the cams? Link to comment Share on other sites More sharing options...
