Kwhistle Posted June 10, 2010 Share Posted June 10, 2010 I had to replace the boot that goes over the inner tie rod. Had some trouble loosening the jam nut, so the whole tie rod was all over the place. Once I finally got it off, noticed that there was a small amount of grease leaking from the boot on the outer tie rod end. There is a ring restricting the boot at the larger diameter, but nothing on top. I pried the boot with a screwdriver and injected some grease in there -- I have a small syringe I packed with grease -- but it seems like a little bit was still seeping out of it. How bad is it? Should I replace the tie rod end or not worry about it for the time being, since there are no problems otherwise? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 10, 2010 Share Posted June 10, 2010 nothing to worry about. subaru tie rods are insanely robust, failure is almost unheard of. i've seen them squeeze a little grease out before when doing work up front too. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted June 10, 2010 Share Posted June 10, 2010 I am thinking that squirting out a little grease is not anything to worry about. However, try yanking back and forth on the tie rod to see if there is any wear that has created "play" or looseness at the joint. I rather doubt that you will find any play, but if so, then consider replacement. Quote Link to comment Share on other sites More sharing options...
Kwhistle Posted June 10, 2010 Author Share Posted June 10, 2010 Thanks guys! No, no play there. Just a little grease came off the top when I was taking out/installing it. Quote Link to comment Share on other sites More sharing options...
