Dannomanno Posted June 11, 2010 Share Posted June 11, 2010 Is there any other way besides the ob strut swap to be able to fit larger tires on a 91 legacy? Link to comment Share on other sites More sharing options...
2.5_IMP Posted June 11, 2010 Share Posted June 11, 2010 http://www.subtle-solutions.com/product_info.php?products_id=107 Link to comment Share on other sites More sharing options...
johnceggleston Posted June 11, 2010 Share Posted June 11, 2010 2.5_IMP said: http://www.subtle-solutions.com/product_info.php?products_id=107 the above will lift the car off the ground more and probably give you more room for a larger tire when turning, but it will not give you more room between the tire and the spring perch. is that even a concern? Link to comment Share on other sites More sharing options...
Dannomanno Posted June 11, 2010 Author Share Posted June 11, 2010 Clearing the strut perch is actually the problem I am trying to get around. Already have a friend milling a set of spacers just Want to put the 205/75/15 off my old ladies Forester on and can't clear em. Was just wonderin if there were multiple options or just the one way to go? Link to comment Share on other sites More sharing options...
