Realy Desperate now ! help !
ok so next week in north iceland we have a 5 day festival translated roughly as "cardays"
i´ve been looking forward to this the whole year but now i have a problem
my carb has issues to say the least,
sometimes it is compleatly normal, drives like new
sometimes it refuses to idle, it´s just like on/off it wont idle for 2 minutes and then starts idleing again
sometimes it feels like the low speed needle stops working, it will only run on idle or full throttle.
and now today it has been lacking all top end power and started over flooding the engine with the only way to get it started again was a pull-start
please if you have ANY idea please share
Have you cleaned the carb? Perhaps a good cleaning and zeroing all the jet settings and moving them to 50% (count the number of turns from all the way in to all the way out)
Intermittent issues could be ignition related as well, make sure your distributor is adjusted correctly and tight.
May be time for a Weber carburetor if money allows.
