logic23 Posted June 22, 2010 Share Posted June 22, 2010 I was wondering what you guys ( 360...nipper) were charging in labor to do headgaskets on the phase 2 engines? Do you break it down into categories like remove and reinstall engine $xxx disassemble-reassemble engine $xxx change all seals etc $xxx. Thanks guys Quote Link to comment Share on other sites More sharing options...
Scoobywagon Posted June 22, 2010 Share Posted June 22, 2010 I don't know what anyone in particular is charging for labor, but I can tell you what alldata has to say on the matter. For a 2001 Forester, book time is 10.2 hours for headgaskets not including any machine time. For clarity, that would be 10.2 hours to remove the engine, tear it down, clean, reassemble, reinstall. Again, that does NOT include any time required for machine work. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 22, 2010 Share Posted June 22, 2010 it's not typically broken down into categories like you're mentioning. i mean from a developmental level those hours are sort of calculated that way, but nothing quantitative that's common and we can outline right here. Skip has a great website about a breakdown of all the work and hours for each step of the job and parts prices, etc. Would that help you - just google for skips EJ25 headgasket page or something. it often depends on what all is being done too. a basic gasket slap - no machining, no extras, nothing, just gaskets and necessary seals - is going to be much cheaper than going the whole 9 yards - machining, cleaning, all new valve cover gaskets, grommets, seals, reseal oil pump, separator plate upgrade, etc. are you having a shop or dealer do this or what? might help to know why you're asking. dealer prices typically range from $1,000 - $1,500 depending on various things like mentioned above. Quote Link to comment Share on other sites More sharing options...
logic23 Posted June 23, 2010 Author Share Posted June 23, 2010 I'm doing the work for a customer. Ive done several but it was only on cars I was flipping. just wondering what the non dealer rate would be. Doing: headgaskets all oil seals valve cover gaskets intake gaskets new clutch timing belt all tensioners waterpump reseal oil pan and rear baffle separator resurface heads and flywheel Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 23, 2010 Share Posted June 23, 2010 (edited) there's a lot of variable to this that are hard to put a price tag on or compare. given a day or two full days work how much is it worth to you? $500 + $500 parts puts it at $1,000. that's as much or less than a dealer but you're doing far more than the head gaskets. adjust that figure up or down as you see fit given the customer, your experience, your time, skills, local economy, local subaru market etc. Edited June 23, 2010 by grossgary Quote Link to comment Share on other sites More sharing options...
davebugs Posted June 23, 2010 Share Posted June 23, 2010 I do them to flip them as well - and not for others. Infact that's a line I still choose not to cross. Basically I figure 1k to either "redo" the 2.5 or swap in a 2.2. Seals, 2.5 HG's, idlers, belts, WP, fluids and filters, spark plugs, reseal baffle plate, ets. The oil pan, clutch, flywheel resurface, heads machined would be on top of that. Breaks down to a long day. Of for me actually 2 partial days. Because I drop the rediator (on a 2.5) to be flushed/tested on the way to drop off the heads by mid afternoon. Them mid morning the next day I make the same look and pick the parts up. I wouldn't do it for anyone(a customer) at virtually any price though. Quote Link to comment Share on other sites More sharing options...
Scoobywagon Posted June 23, 2010 Share Posted June 23, 2010 If you're starting to do that kind of work, SERIOUSLY...invest in an alldata subscription. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 23, 2010 Share Posted June 23, 2010 I would say that 10.2 hours is a good estimate, but ONLY for the actual head gaskets. If there are other things that are being done at the same time then more time needs to be added in. GD Quote Link to comment Share on other sites More sharing options...
