OREchipmunk78 Posted June 23, 2010 Share Posted June 23, 2010 how rare are front wheel drive subbie gl wagons?:confused: Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 23, 2010 Share Posted June 23, 2010 Pretty common actually. Not desireable. GD Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 23, 2010 Share Posted June 23, 2010 Well if you get a 4WD rear trailing arm and 3.9 rear diff along with a 4WD trans and trans crossmember you could always swap it to being 4WD! Easy enough really.. Quote Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted June 23, 2010 Share Posted June 23, 2010 Well if you get a 4WD rear trailing arm and 3.9 rear diff along with a 4WD trans and trans crossmember you could always swap it to being 4WD! Easy enough really.. Ummm, you're forgetting the gas tank and the driveshaft. And the axles. And its also dependent if its an EA81 or EA82. But anyway, they're very common and only wanted for their fuel economy. Otherwise, get a 4x4 and ignore the 1-2 mpg drop. Twitch Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted June 23, 2010 Share Posted June 23, 2010 Whoops, well I'm not gonna get into complete details on something that most liklie isn't going to happen. But your right. I'm thinking its an EA82.. Quote Link to comment Share on other sites More sharing options...
zyewdall Posted June 24, 2010 Share Posted June 24, 2010 I had an EA81 fwd.... nice enough car (okay, it was a free rustbucket beater... but, it ran well, and you could pack alot into it). It was quite a bit peppier than the 4wd ones, but of course, not nearly as good at offroading (I still took it offroading....) Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted June 24, 2010 Share Posted June 24, 2010 how rare are front wheel drive subbie gl wagons?:confused: really rare around here. I think the only one we know of in the past 5 years sited, McBrat just dismantled..... so VERY rare indeed for here I came across one in the pick n pull about 3 years ago, havent seen one there since. Quote Link to comment Share on other sites More sharing options...
Subaru_dude Posted June 25, 2010 Share Posted June 25, 2010 If it's an EA82 you won't have to do anything with the gas tank. I swapped donor parts from a 4wd onto a 2wd and there were no problems with the tank. I don't know about EA81s though... Quote Link to comment Share on other sites More sharing options...
OREchipmunk78 Posted June 25, 2010 Author Share Posted June 25, 2010 it is an EA82 and thanks for the input... I bought this car for 175 bucks and did a little work to it (i.e. timing belt, fuel pump, tranny, gas tank...) and now am looking to sell it... How much do you think I could get? the body is in primo shape and it runs like a champ. I drove it for a couple of months and it averages about 27mpg... But it is a beautiful car for its age... Quote Link to comment Share on other sites More sharing options...
