1-3-2-4 Posted June 23, 2010 Share Posted June 23, 2010 Does anyone know where it's located? Someplace around the upper area of the glove box? Link to comment Share on other sites More sharing options...
TheLoyale Posted June 23, 2010 Share Posted June 23, 2010 You can access it by removing the passenger side air bezzle (Closest to the door) Easy to get to. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 23, 2010 Author Share Posted June 23, 2010 TheLoyale said: You can access it by removing the passenger side air bezzle (Closest to the door) Easy to get to. I will try it after work today I just brought a lock timer from ebay lol Link to comment Share on other sites More sharing options...
TheLoyale Posted June 23, 2010 Share Posted June 23, 2010 1-3-2-4 said: I will try it after work today I just brought a lock timer from ebay lol Of course, where else can you find great deals... :-p PS: The vent just pulls out, Kinda pully up on it then out. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 25, 2010 Author Share Posted June 25, 2010 Finally saw it but I can't figure out how to remove it.. I did crack the vent removing it... But funny thing is As soon as I removed it and tapped on the door timer my doors have been all locking and unlocking like they should now. Link to comment Share on other sites More sharing options...
TheLoyale Posted June 25, 2010 Share Posted June 25, 2010 There is one 10mm bolt holding the housing which I guess it clips to. At least from I remember seeing. It could just be getting sticky and a few taps fixed it for now. I almost cracked the vent frame when I took it out, (Got lucky) Good luck to ya! Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 25, 2010 Author Share Posted June 25, 2010 TheLoyale said: There is one 10mm bolt holding the housing which I guess it clips to. At least from I remember seeing. It could just be getting sticky and a few taps fixed it for now. I almost cracked the vent frame when I took it out, (Got lucky) Good luck to ya! Yeah I saw the bolt too but unsure where to find a good angle to get in. Link to comment Share on other sites More sharing options...
TheLoyale Posted June 25, 2010 Share Posted June 25, 2010 Well I'm thinking you should be able to get a box wrench in there and then just break the torque on it, then you should be able to remove the screw with your fingers. I forgot if you can get that high up in the dash from going under the dash. Tip in case of: Removing the Glove box does nothing for you. I've done that already for the hell of it Lol! Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 25, 2010 Author Share Posted June 25, 2010 haha I know all about the removing the glove box so close but all that metal is in the way I'd have to see if I have a box wrench in that size. Link to comment Share on other sites More sharing options...
TheLoyale Posted June 25, 2010 Share Posted June 25, 2010 1-3-2-4 said: haha I know all about the removing the glove box so close but all that metal is in the way I'd have to see if I have a box wrench in that size. A Subaru owner without a 10mm wrench! C'mon, you can take apart an entire Soob with a 10mm wrench :-p Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 25, 2010 Author Share Posted June 25, 2010 door timer came but man I was expecting just the door timer but what is this metal case behind it? Link to comment Share on other sites More sharing options...
TheLoyale Posted June 25, 2010 Share Posted June 25, 2010 That could be the box that reads if your Seat belts are being used. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 28, 2010 Author Share Posted September 28, 2010 just wanted to update this thread.. it was indeed my door lock timer causing my doors to try and keep locking on it's own or not responding to any position that the driver's side door lock was in. Everyone kept telling me to check the drivers door but I knew that was not the issue because it was centered around the glove box area.. and sure enough it did not take long to figure the problem out as soon as i touched the door lock timer case. Also that silver box is the cruse control unit I did not need it so I have an extra on hand. Link to comment Share on other sites More sharing options...
idosubaru Posted September 28, 2010 Share Posted September 28, 2010 great thanks for following up my LSi is doing the same exact thing. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 28, 2010 Author Share Posted September 28, 2010 It's a little confusing to get to.. but I had to pop the clip off the dash part between the dash and the door it's a single screw and the rest should be easy the hardest part was getting the dash part to snap back in the bracket. Glad I took care of it and in the rain! Oh yeah be careful some of that metal that is from the steering bracket is a bit sharp had to shed a little blood today. I'm going to open up the old one. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 28, 2010 Author Share Posted September 28, 2010 Not much to it.. Link to comment Share on other sites More sharing options...
idosubaru Posted September 28, 2010 Share Posted September 28, 2010 so it's close to the passengers side door? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 28, 2010 Author Share Posted September 28, 2010 grossgary said: so it's close to the passengers side door? here is a video should clue you in. you will need to take out the passenger side vent and pull it out from under the dash part it's about knee level in the car when you sit. Link to comment Share on other sites More sharing options...
idosubaru Posted October 1, 2010 Share Posted October 1, 2010 i've spent a gob of time upside down with my head in the footwell area looking for this timer. the pictures are great that 1-3-2-4 posted but i can't tell what angle those are relative too. the yellow air bag line is the most telling but i still can't seem to see where this thing is. almost positive it's on the passengers side like 1-3-2-4's since i hear it clicking when i work the locks. internet connection where the car is won't work with video so i can't use that link he posted. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 1, 2010 Author Share Posted October 1, 2010 Yeah it's a tight/funny spot if you are on your back it's harder kinda hard to describe how it is two bolts old it down the lower bracket and one at the top and then one for the door lock timer I think it was 10mm I used. Link to comment Share on other sites More sharing options...
idosubaru Posted October 1, 2010 Share Posted October 1, 2010 you access it all from underneath - like right by the blower motor? do you remove anything else? i removed the bolt on the side of the dash but that doesn't allow it to move at all. removed two screws underneath and the dash isn't budging, not sure where all the dash attaching points are. the FSM is worthless it shows an ambiguous picture with no surrounding clues/orientation. doesn't even show what side or where it is in the car. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 1, 2010 Author Share Posted October 1, 2010 grossgary said: you access it all from underneath - like right by the blower motor? do you remove anything else? i removed the bolt on the side of the dash but that doesn't allow it to move at all. removed two screws underneath and the dash isn't budging, not sure where all the dash attaching points are. the FSM is worthless it shows an ambiguous picture with no surrounding clues/orientation. doesn't even show what side or where it is in the car. Yeah it's right by the blower motor but on the other side of that metal bracket It took me a little bit to get access at the screw since the bracket was a little hard to turn due to space but it's doable you have to take out the glove box and the glovebox support bar. and then you need to unscrew those two screws that hold the dash panel that metal piece. Also careful on tugging on it and don't misplace the clip that is going to fall out the dash snap in just above where the bracket that has the door lock timer on it. You will see it on the backside it's like a 2 inch long pointy peice and yes the FSM sucked for this I pretty much had to find a way on my own :-/ I had no luck on removing the door lock timer off the bracket.. the old one I had I had to rip it off the bracket despite of it I guess being a snap/slide in. Link to comment Share on other sites More sharing options...
idosubaru Posted October 4, 2010 Share Posted October 4, 2010 great, that might be the problem. i saw another thread that i thought someone said removing the glove box didn't help. so nevermind that, i'll take it out tomorrow. thanks. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 3, 2010 Author Share Posted December 3, 2010 How did everything go did you ever get to change it out? Link to comment Share on other sites More sharing options...
idosubaru Posted December 4, 2010 Share Posted December 4, 2010 no man....i never could find the freaking thing. i still haven't removed the glove box since someone mentioned that needs to come out though. maybe that's holding me up, i hope so because i wasn't getting anywhere and it was annoying. funny thing - my locks have worked perfectly since scrounging around back there so that's reduced my desire to wrestle with it. Link to comment Share on other sites More sharing options...
