brysawn Posted June 23, 2010 Share Posted June 23, 2010 For the last week now I have been creating some stuff to make a mild "wheeler" out of my loyale. Here are my phone pictures along the way. These are my lift blocks: (pre-welding) (welded and painted) And this is my 6 lug hub. I haven't done my drums yet. This hub is 6x5.5 using Toyota 4runner studs, because of the specific lug nuts my Toyota wheels require. (on this hub, one of the studs is crooked because I didn't grind down the uneven surface on the back of the hub. it still fits in the wheel great, and everything tightens down, so I figured it doesn't really matter.) everything should be going on this weekend. Quote Link to comment Share on other sites More sharing options...
monstaru Posted June 23, 2010 Share Posted June 23, 2010 (edited) its a pain in the rump roast huh?:lol:what helped me when i did it was to take just a tad bit of meat off at a time.it really will make the fit easier to deal with .the studs can get cockeyed from being jolted around when they are mounted on the car....it is wise to take care of that issue before it really becomes an ISSUE.....cheers, brian Edited June 23, 2010 by monstaru more info Quote Link to comment Share on other sites More sharing options...
brysawn Posted June 24, 2010 Author Share Posted June 24, 2010 its a pain in the rump roast huh?:lol:what helped me when i did it was to take just a tad bit of meat off at a time.it really will make the fit easier to deal with .the studs can get cockeyed from being jolted around when they are mounted on the car....it is wise to take care of that issue before it really becomes an ISSUE.....cheers, brian yeah I should have done that, but they are all welded in the hub, so I don't think that one should be an issue. But the others will all be ground flat before I put the studs in. But on another note; tires. As of now I'm thinking about the general grabber at2 or the falken high country at, both in a 215/75/15 which is around a 27" overall height. I want mud terrain tire, but I don't want to spend much over 100 a tire. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Markus56 Posted June 24, 2010 Share Posted June 24, 2010 But on another note; tires. As of now I'm thinking about the general grabber at2 or the falken high country at, both in a 215/75/15 which is around a 27" overall height. I want mud terrain tire, but I don't want to spend much over 100 a tire. Any suggestions? craigslist or a used tire shop Quote Link to comment Share on other sites More sharing options...
Mantis_Toboggan Posted June 24, 2010 Share Posted June 24, 2010 Hey Markus, did you make that bumper yourself? How's it mounted? Quote Link to comment Share on other sites More sharing options...
brysawn Posted June 24, 2010 Author Share Posted June 24, 2010 So far, I'm pretty set on the General Grabber AT2 in a 205/75/15. Any opinions? Quote Link to comment Share on other sites More sharing options...
frogstar7055 Posted June 24, 2010 Share Posted June 24, 2010 So far, I'm pretty set on the General Grabber AT2 in a 205/75/15. Any opinions? It's not a mud tire but it's an excellent all terrain. Quote Link to comment Share on other sites More sharing options...
brysawn Posted June 24, 2010 Author Share Posted June 24, 2010 It's not a mud tire but it's an excellent all terrain. Yeah I know. But for $80 a piece, it's tough to beat. It's also hard to find mud terrain's in that small a size Quote Link to comment Share on other sites More sharing options...
frogstar7055 Posted June 25, 2010 Share Posted June 25, 2010 I'm running Yokohama Geolander A/T S's and got no complaints. Don't know if they come in your size but there not quite as aggressive as the Grabbers. Quote Link to comment Share on other sites More sharing options...
brysawn Posted July 1, 2010 Author Share Posted July 1, 2010 I got my lift finished up and installed, but my car sits crooked now. My passenger side is 1" higher than the drivers. I'm not really sure why. My rear struts (when out of the car) were within 1/8" of each other, as were the fronts. I don't understand Quote Link to comment Share on other sites More sharing options...
Mantis_Toboggan Posted July 1, 2010 Share Posted July 1, 2010 How did you do the install? I hear that some springs need to be clocked in their perches. Got any pics of the struts with the wheels off? Quote Link to comment Share on other sites More sharing options...
brysawn Posted July 1, 2010 Author Share Posted July 1, 2010 The spring was never removed from the strut, just the entire strut from the car Quote Link to comment Share on other sites More sharing options...
daredevil1166 Posted July 1, 2010 Share Posted July 1, 2010 About tires.... I've had the General Grabber AT/2's. They were great for traction but not tough at all. Super soft rubber that chunks out easily. At 10k they were 3/4 through treadwear life as well. I have Geolandar AT/S's now. Traction isn't as good, but they're a much much tougher tire. I've only put about half as many miles on the Geo's as I did the Grabbers but, the treadwear seems much better too. Bad thing is they don't have a 205/75-15. You'd have to go with a 215 in either 70 or 75. Quote Link to comment Share on other sites More sharing options...
brysawn Posted July 1, 2010 Author Share Posted July 1, 2010 Oh thank you, that's good to know. I like the at2's because of the size they come in. If I were to get a 215/75, I would just go for a mud tire Quote Link to comment Share on other sites More sharing options...
brysawn Posted July 15, 2010 Author Share Posted July 15, 2010 Right now I only have one 6-lug hub. So here's my car with the 2" lift, and one of my wheels/tires on. It needs some cutting, I'm not really sure how to go at that Quote Link to comment Share on other sites More sharing options...
3eyedwagon Posted July 16, 2010 Share Posted July 16, 2010 As for your car sitting crooked, two things: 1: Check around all the welds on the extensions for leaks, any sign of "moisture" means that you popped the shock absorber portion of the strut while welding, and the oil is leaking out. It'll make one side sag. 2: You may have welded the extension tubes on at a slight angle. Even the slightest angle inboard/out, forward/aft will cause a big difference in height. I've seen both these things happen on a few rigs that first timers have done this lift on. Quote Link to comment Share on other sites More sharing options...
Pooparu Posted July 16, 2010 Share Posted July 16, 2010 here's how: zzz Right now I only have one 6-lug hub. So here's my car with the 2" lift, and one of my wheels/tires on. It needs some cutting, I'm not really sure how to go at that Quote Link to comment Share on other sites More sharing options...
brysawn Posted July 16, 2010 Author Share Posted July 16, 2010 (edited) As for your car sitting crooked, two things: 2: You may have welded the extension tubes on at a slight angle. Even the slightest angle inboard/out, forward/aft will cause a big difference in height. I've seen both these things happen on a few rigs that first timers have done this lift on. Yeah, that's what happened. The drivers side rear, is a bit crooked. I'm not too concerned now, but it'll be changed soon. Also, my rear wheels aren't centered. They are really close to the door Edited July 16, 2010 by brysawn Quote Link to comment Share on other sites More sharing options...
gwilson87 Posted July 16, 2010 Share Posted July 16, 2010 I hate that you have those toyota wheels only because I wanted those on my brat sooooooooo bad. I had the wheels but didn;t have the funds to do a 6 lug swap or get tires for them. Quote Link to comment Share on other sites More sharing options...
The Scooby Posted July 16, 2010 Share Posted July 16, 2010 It'll make one side sag.. the spring holds the weight of the car, the shock is there to obsorb oscillations of the spring. so in theroy no it won't cause the car to sag, only if you heated the springs to a point that it changed their spring weight because of the temper would it sag. Quote Link to comment Share on other sites More sharing options...
brysawn Posted July 18, 2010 Author Share Posted July 18, 2010 (edited) It rubs in the rear, so I have some more trimming. But I've been driving it a little. So here's the finished (almost) project: Thanks a lot 3eyedwagon for helping me out and answering my many many lift questions Edited July 18, 2010 by brysawn Quote Link to comment Share on other sites More sharing options...
bratman18 Posted July 18, 2010 Share Posted July 18, 2010 You still have a S/R tranny in there? If so and you plan on doing any real off road stuff, you probably want to swap it out for a D/R. Looks good though!! Quote Link to comment Share on other sites More sharing options...
daredevil1166 Posted July 22, 2010 Share Posted July 22, 2010 I like the look of those wheels alot. Very nice. Quote Link to comment Share on other sites More sharing options...
one eye Posted July 29, 2010 Share Posted July 29, 2010 I saw you driving down the Freeway yesterday, right at exit 167 (denny??) I was in the draper valley truck that almost plowed into a yellow Xterra trying to check out your rig!!!.... Looks good going down the road!!!!!!!!!!!!!!!!!!!!!!! Jeff Quote Link to comment Share on other sites More sharing options...
brysawn Posted July 29, 2010 Author Share Posted July 29, 2010 I saw you driving down the Freeway yesterday, right at exit 167 (denny??) I was in the draper valley truck that almost plowed into a yellow Xterra trying to check out your rig!!!.... Looks good going down the road!!!!!!!!!!!!!!!!!!!!!!! Jeff Thanks! I can't wait to get in a D/R and go wheeling. That must have been around 6ish (going to the sounders game) Quote Link to comment Share on other sites More sharing options...
