monstaru Posted June 24, 2010 Share Posted June 24, 2010 (edited) bumpers...... ok folks, here are some examples of what you can do with a a bit of inginuity , or resourcefulness ......... Edited June 29, 2010 by monstaru Link to comment Share on other sites More sharing options...
UraBUS09 Posted June 24, 2010 Share Posted June 24, 2010 brushguard/winch bumper off 79 brat. made to fit. going to paint it soon. just need the winch to make it right... Link to comment Share on other sites More sharing options...
Uberoo Posted June 24, 2010 Share Posted June 24, 2010 heres my bumper before I added D ring shackles to the front of it with 3/4" blocks. Bumper is a piece of L channel about 3/16 thick.It is held to the car with some C channel thick wall 2" c Channel.Bumper mounts go into the car 22" with 3 7/16 bolts on each side holding it on. It held up until I got my car stuck in some cement like mud up to bumper.the recovery effort bent the bumper itself and bent a channel support.not to mention, it pulled the bumper a little less than 1/2 an inch further forward in the body(tore the sheetmetal a little) Link to comment Share on other sites More sharing options...
bratman18 Posted June 24, 2010 Share Posted June 24, 2010 Link to comment Share on other sites More sharing options...
Markus56 Posted June 24, 2010 Share Posted June 24, 2010 (edited) Brush guard taken from a Isuzu pickup and welded to a piece of channel, which is attached to 2x2 steel bolted to the stock bumper mount Edited June 24, 2010 by Markus56 Link to comment Share on other sites More sharing options...
bheinen74 Posted June 24, 2010 Share Posted June 24, 2010 Link to comment Share on other sites More sharing options...
one eye Posted June 24, 2010 Share Posted June 24, 2010 (edited) A work in progress.................. still needs the skid plate part but its coming along................ Jeff Edited June 25, 2010 by one eye Link to comment Share on other sites More sharing options...
A DOG Posted June 24, 2010 Share Posted June 24, 2010 It was soo long ago. But i think Allied Armament made this one of a kind EA81 bumper for me. It was strong and looked great!!! Link to comment Share on other sites More sharing options...
mcbrat Posted June 25, 2010 Share Posted June 25, 2010 Link to comment Share on other sites More sharing options...
MysteriousXTC Posted June 25, 2010 Share Posted June 25, 2010 Link to comment Share on other sites More sharing options...
Turbone Posted June 25, 2010 Share Posted June 25, 2010 (edited) My Hatch... Edited June 25, 2010 by Qman Link to comment Share on other sites More sharing options...
Pooparu Posted June 25, 2010 Share Posted June 25, 2010 Link to comment Share on other sites More sharing options...
frogstar7055 Posted June 25, 2010 Share Posted June 25, 2010 Pooparu said: I really like that. Link to comment Share on other sites More sharing options...
Pooparu Posted June 25, 2010 Share Posted June 25, 2010 Built by "the beast i drive" aka bill. Link to comment Share on other sites More sharing options...
tractor pole Posted June 25, 2010 Share Posted June 25, 2010 MysteriousXTC said: :slobber::slobber: I really like that bumper. did you build it? Link to comment Share on other sites More sharing options...
jbbvw Posted June 26, 2010 Share Posted June 26, 2010 Link to comment Share on other sites More sharing options...
obk25xt Posted June 27, 2010 Share Posted June 27, 2010 (edited) Edited July 10, 2010 by obk25xt Link to comment Share on other sites More sharing options...
987687 Posted July 7, 2010 Share Posted July 7, 2010 not done yet, but a work in progress. Link to comment Share on other sites More sharing options...
one eye Posted July 7, 2010 Share Posted July 7, 2010 Jeff Link to comment Share on other sites More sharing options...
The Scooby Posted July 8, 2010 Share Posted July 8, 2010 looks good jeff front i made, the rear i think monstaru made years back for a EA81 and i cut off the mounts, rewelded them then plated the frame and bolted it all the way through. been used more then a few times to yank hard on F150's that get stuck in ditches. Link to comment Share on other sites More sharing options...
Mugs Posted July 21, 2010 Share Posted July 21, 2010 2 x 2 in square tubing. with the push bar following the lines of the head lights. Big bolts and washers that go all the way through the body via the stock mounting holes. D-rings tripple pass welded...I know, that you know, that I know, these suckers hold Skid plate bolted to the bumper then bolts to the tranny cross member. Rear same but used angle iron to make a bracket to tie into the stock hole locations. And then made a bracket that has a plate welded to the bottom of it (flat bar side by side then a plate on the top) which ties into the tie down holes. Front: Rear: Link to comment Share on other sites More sharing options...
frogstar7055 Posted July 22, 2010 Share Posted July 22, 2010 ^ very nice,like the recovery shackles. Link to comment Share on other sites More sharing options...
