ShawnW Posted June 24, 2010 Share Posted June 24, 2010 I just got done swapping in an LSD from an 85 RX Sedan with 104K on it into my Impreza. I used the RX external stubs and Legacy rear axles from a 91 Turbo. Everything fit as I figured it would. It makes a weird clicking noise when I roll down the road in gear or out. I used Synthetic 75W90 gear oil and a bottle of BG LSD additive. This has been fine in the past on old gen LSD conversions. Ideas or suggestions are appreciated. I did do the disc brakes and rear struts at the same time as the LSD swap but don't think thats necessarily the problem. Link to comment Share on other sites More sharing options...
idosubaru Posted June 24, 2010 Share Posted June 24, 2010 could you get it spinning in the air and see if it makes noise you can track with a stethoscope? being unloaded it might not make any noise though. if it's diff related you might narrow it down to bearing surface or internals. i assume you drove this car before all this swapping and no noises? Link to comment Share on other sites More sharing options...
ShawnW Posted June 24, 2010 Author Share Posted June 24, 2010 Right, no noises before the diff swap. Link to comment Share on other sites More sharing options...
monstaru Posted June 24, 2010 Share Posted June 24, 2010 were the axles hard to get on?they may be to compressed , or to short? i am assuming that you spun the diff a few times with stubs in it out of the car,you know, by turning the pinion?etc......cheers, brian Link to comment Share on other sites More sharing options...
ShawnW Posted June 24, 2010 Author Share Posted June 24, 2010 They were easy to get on felt like they belonged on it. My buddy Max runs a similar setup in his rallyx car but his car is too noisy to notice if the diff makes this noise. The only thing I found odd during the installation was turning the rear wheels seemed a little difficult by hand after all was together. Link to comment Share on other sites More sharing options...
bheinen74 Posted June 24, 2010 Share Posted June 24, 2010 Shawn. Can you maybe pop off each rear axle and spin each tire to see if the noise is coming from the hub/tire side, then with both axles popped off, spin the driveshaft which should spin the guts of the diff....to narrow down the noise if you havent done so. if the noise a click click click, or a pop pop pop....and in the diff without axles connected....you may have done this test. Link to comment Share on other sites More sharing options...
ShawnW Posted June 25, 2010 Author Share Posted June 25, 2010 At very slow speed you can't hear it it just gets a little noisy around 10-15 mph Im not sure you would be able to hear it from under the car at all. I have driven it on jack stands thru the gears and can't hear anything but I have the exhaust, engine, etc to contend with. Link to comment Share on other sites More sharing options...
monstaru Posted June 25, 2010 Share Posted June 25, 2010 did someone leave a card in your spoke?:grin:cheers, brian Link to comment Share on other sites More sharing options...
ShawnW Posted June 25, 2010 Author Share Posted June 25, 2010 Thats exactly what it reminded me of the first time I drove it! Link to comment Share on other sites More sharing options...
oskar_subaru Posted June 25, 2010 Share Posted June 25, 2010 you´re not using the same axles if i understand correctly, could the clicking not be from one of the axle joints ? Link to comment Share on other sites More sharing options...
WoodsWagon Posted June 29, 2010 Share Posted June 29, 2010 There's been some problems with the lip on the rear backing plate interfering with the groove on the rotor hat and making noises like that. You may have moved something enough when you were installing the diff to cause problems mabe? Link to comment Share on other sites More sharing options...
oskar_subaru Posted June 29, 2010 Share Posted June 29, 2010 There's been some problems with the lip on the rear backing plate interfering with the groove on the rotor hat and making noises like that. You may have moved something enough when you were installing the diff to cause problems mabe? x2 worth looking into, but every time that´s happened to me, it´s more of a scraping sound than a clicking sound Link to comment Share on other sites More sharing options...
ShawnW Posted June 29, 2010 Author Share Posted June 29, 2010 Like the ABS sensor rubbing or something like that? Link to comment Share on other sites More sharing options...
oskar_subaru Posted June 30, 2010 Share Posted June 30, 2010 Like the ABS sensor rubbing or something like that? no the sheet metal backing plate Link to comment Share on other sites More sharing options...
