NewKens1 Posted June 25, 2010 Share Posted June 25, 2010 How do I remove the turn signal switch on a '2000 OBW? Quote Link to comment Share on other sites More sharing options...
94Loyale Posted June 25, 2010 Share Posted June 25, 2010 Remove the 2 plastic surrounding pieces that cover the steering column. At the bottom of the t/s stalk is two phillips screws, take them out and unplug. Easy as that Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted June 25, 2010 Share Posted June 25, 2010 Remove the 2 plastic surrounding pieces that cover the steering column. At the bottom of the t/s stalk is two phillips screws, take them out and unplug. Easy as that Love how Subarus are easy to work on! Quote Link to comment Share on other sites More sharing options...
94Loyale Posted June 25, 2010 Share Posted June 25, 2010 Love how Subarus are easy to work on! Isn't it great? The secret of all that, is the flasher is inside the switch too Knowing that will save you a lot of time if you ever need to look for it to diagnose. Quote Link to comment Share on other sites More sharing options...
