EA82T Injector flow rate
Hi,
Searched and found that XT injector flow rates are 185cc, but just wondering what the L series EA82T injector flow rates are?
About to take my megasquirted EA82T in a VW based replica car to a rolling road for tuning and it would help to know the injector flow rate - thanks a million if anyone can tell me.
  habib99 said:
Hi,
http://www.ultimatesubaru.org/forum/showthread.php?t=35326&highlight=fuel+injector
"The RX turbo injectors flow an average of 245cc/min."
Hi. I think we chatted once before. I'm runnin' an 88 GL 10 Turbo, with heads hogged & polished, every thing match ported, no cats & a 2.5" glass pack, boost referenced pres. reg. & adj. boost limiter. I'm running 380 cc injectors w/ a stock ECU, & it runs really strong @ 14 psi, with no fuel cut out. If your lookin' to up size your injectors, ******. with Charlie @ Osidetiger.com. He'll make you any flow rate you want, my set came with flow charts, all new stainless hardware, hoses, wire ends, etc., direct bolt in, to my door for just under $200. Luck with your project. S.
:eek: I wish I knew this when I had a RX turbo. I'm tempted to pick up a set of injectors, just in case I get another one. :slobber: I could have really used those.
