bgambino Posted June 26, 2010 Share Posted June 26, 2010 having driven soobs since 1980, I've done a few T belt jobs in later years on the GL's. I have not had one of these older styles for quite a few years and recently bought a beautiful 93 loyale with 40k on her. I bought a T belt kit with the pulleys from ebay. figured they are 17 years old and the kit was cheap enough My questions is...would the R & R and adjustment of the belts be identical to my old haynes repair book which only covers up to 1988? I would assume it would be thanks in advance Link to comment Share on other sites More sharing options...
john in KY Posted June 26, 2010 Share Posted June 26, 2010 Nothing changed. just be sure to rotate the engine one full revolution after installing the first belt and make sure you use the correct marks on the flywheel. Link to comment Share on other sites More sharing options...
somick Posted June 26, 2010 Share Posted June 26, 2010 http://www.ultimatesubaru.org/forum/showthread.php?t=48341 See if that link will help you. Good luck, Sam Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 26, 2010 Share Posted June 26, 2010 It's identical to your manual - they didn't change the EA82's much after about '87.5 GD Link to comment Share on other sites More sharing options...
