tires for a 91 legacy
Markus56
I believe that you won't have to do anything.. I plan on putting them on my 90 legacy and I found that the biggest that would fit on the first gen legacys is a 215/60/16 and I put the two tires in a tire calculated and the bf goodrich tire is actualy I little bit smaller than that so u should be good on just slapping them on and it'll give about an inch lift if your runnin the stock size. Btw I think they are cheaper on tirerack.com..
