brysawn Posted June 28, 2010 Share Posted June 28, 2010 When turning one direction, I have this annoying grinding sound coming from my driver side front brakes/suspension. It sounds like metal on metal, or like my brakes are rubbing, or something. But when I take it apart and look around, I can't figure out what it is. It doesn't seem to be affecting anything, but I can't stand the annoying sound. Oh, and the car is a 94 loyale Quote Link to comment Share on other sites More sharing options...
tractor pole Posted June 28, 2010 Share Posted June 28, 2010 broken front brake hardware clips, at least that is what was making noise on mine. Quote Link to comment Share on other sites More sharing options...
brysawn Posted June 29, 2010 Author Share Posted June 29, 2010 Naw, it wasn't that. Any other ideas? Quote Link to comment Share on other sites More sharing options...
naru Posted June 29, 2010 Share Posted June 29, 2010 Loose wheel bearing. Jack it up and attempt to wiggle the wheel to check. Quote Link to comment Share on other sites More sharing options...
MaddCelt Posted June 29, 2010 Share Posted June 29, 2010 Might want to look into a CV joint. Mine does the same thing. If it is you will want to get it fixed ASAP. Metal on metal is bad and will only get worse. Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted July 1, 2010 Share Posted July 1, 2010 could even be something like the parking brake cable binding and its effectively applying the (front) parking brake when you turn. Does it happen in either direction or only one?? Quote Link to comment Share on other sites More sharing options...
TeamCF Posted July 2, 2010 Share Posted July 2, 2010 +1 on checking the wheel bearing. I know mine are due for replacement and and everytime I turn the rotor rubs the shield. Guess I should just go bend the shield out a bit until I come up with bearing $$$. Jack up the car, grab the tire top and bottom and see if you can wiggle it. there with be a definite small *clunk clunk* back and forth. Now, slop could be a ball joint as well so inspect good. Also note if there is any growling when going down the freeway. Mine just started that up last time I drove it. I'd then start with checking the torque of the axle nut. I'm not sure on the Loyale, but on mine (EA81), the bearings are not adjustable. They are sloppy or they are not. My axle nuts are properly torqued and still the bearings are loose. So in my case I just need new ones. Your results may vary. Quote Link to comment Share on other sites More sharing options...
mike97 Posted October 25, 2010 Share Posted October 25, 2010 did you figer out what was makeing the noise Quote Link to comment Share on other sites More sharing options...
Ricearu Posted October 25, 2010 Share Posted October 25, 2010 it could also be a front hub stripped, that is if your car is FT4WD Quote Link to comment Share on other sites More sharing options...
brysawn Posted October 25, 2010 Author Share Posted October 25, 2010 It was my axle. But the car has been parked until next summer, so it's not going to bother me much now. Quote Link to comment Share on other sites More sharing options...
