JAR Posted June 28, 2010 Share Posted June 28, 2010 Thanks for any help with this. 1996 2.2 Legacy Wagon The car starts fine when it's been sitting for at least a couple of hours, but if I turn it off then back on again sometimes it will just turn over and not start. Push starting it does work. Check engine light came on when problem started and has been on since. I have had this problem before and the dealer told me it was a recalled item and fixed it for free. I talked to another dealership today the person wasn't familiar with the problem. I think I remember them telling me it was just some sort of sensor that was bad. Any ideas on what it is would be appreciated. Link to comment Share on other sites More sharing options...
davebugs Posted June 28, 2010 Share Posted June 28, 2010 I've had this happen with a 2.2 swap and it seemed to be due to a bad crank sensor. But I don't think it would run if push started. So perhaps that isn't it. You have checked the wireing to all the key sensors? You are aware most auto parts chains will read the code for free? You are aware that an ODB2 reader to buy is only 50 bucks? And welcome to the board! Please update your location so that it displays. Perhaps you're close to a member. Often members here are willing to assist. But we're not so good at guessing where folks are located. Link to comment Share on other sites More sharing options...
Olnick Posted June 28, 2010 Share Posted June 28, 2010 Welcome! And +1 to what davebugs said. Get the codes pulled and let us know what they are--get the number (P0xxx) and not some verbal description. It's better than just guessing and throwing parts at it. Hey, if the car wants to tell you what's wrong, take advantage of it! Link to comment Share on other sites More sharing options...
porcupine73 Posted June 29, 2010 Share Posted June 29, 2010 Right on, we need the code number. That said my '96 2.2L is also doing what you describe, it won't start sometimes and the MIL illiuminates. My code is always something to do with crank position sensor circuit and it will start if tap on that sensor a bit. Link to comment Share on other sites More sharing options...
