lone500 Posted June 29, 2010 Share Posted June 29, 2010 my car is a 94 legacy. i stopped getting anything from the cylinder closest to the driver seat. checked plugs, wires and stuff and they were all fine and then switched injectors to see if that was the problem and it wasnt. so can anyone tell me what might be the problem? Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted June 29, 2010 Share Posted June 29, 2010 coil pack? igniter? do a compression check, properly and tell us what the results are. spark compression air fuel thats it. Quote Link to comment Share on other sites More sharing options...
Olnick Posted June 29, 2010 Share Posted June 29, 2010 Sorry but a whole bunch of questions jump to mind: What are the symptoms--driveability? Non-start? How did you find the "bad" cylinder? CEL? Did you pull the codes? You say you checked plugs & wires--did you try swapping them around? Give us all the specifics that you can and maybe a light will go on somewhere! Good luck. Quote Link to comment Share on other sites More sharing options...
lone500 Posted June 29, 2010 Author Share Posted June 29, 2010 ya i already figured on doing a compression test. gonna borrow a friends tommarow. ive had a code 35 for a long time and i dont know if its showing any other codes or anything. uh when it happened i was going to a friends house. went fine out the driveway and down the road to the interstate. got on and after a little while i noticed i didnt have near as much power as i should have. wasnt pulling up hills right and everything. when i got off at the exit i was going to i noticed it downshifted fine down to my stop at the light. when i went to turn and took off i noticed bad hesitation and that i surely wasnt getting the power i should because of the way it was revving up and eveything and by how bad it idled. took it to my friends house and checked plugs and wires. the plug in the cylinder im having problems with was really black and nasty and was fouled out. so i picked up a set and replaced all the plugs. switched wires and all that to make sure they were all good. all getting strong sparks and everything. changed injectors around and found it wasnt the injector at fault. the problem still remains in that cylinder. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 29, 2010 Share Posted June 29, 2010 Cracked piston comes to mind. If the plug is oil fouled then you're gonna need to pull the cylinder head and take a peek. Quote Link to comment Share on other sites More sharing options...
Olnick Posted June 29, 2010 Share Posted June 29, 2010 Thanks for the details, lone500. Did the other 3 plugs look okay to you? You might want to pull the codes again to see if anything new has shown up. Let's hope someone knowledgable chimes in here. Quote Link to comment Share on other sites More sharing options...
lone500 Posted June 29, 2010 Author Share Posted June 29, 2010 how exactly do i pull the codes for it? the other 3 plugs looked like they were burning a little rich and hot but nothing to abnormal. the one plug had black junk fouling it all up. just waiting to do compression test tommarow and everything. but my thought is the rings are gone and the pistons cracked possibly. btw the rings havent been to awesome for a while. my car had a salvaged title. the engine was immaculate when i got it. i think they rebuilt it and didnt hone the cylinders and nows the time that one crapped out. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted June 29, 2010 Share Posted June 29, 2010 If compression on that cylinder is low, it might make more sense financially, to swap in a used 2.2 motor. They can be had for not much money. That is what I did when I owned my 91 Leggie. Quote Link to comment Share on other sites More sharing options...
lone500 Posted June 29, 2010 Author Share Posted June 29, 2010 If compression on that cylinder is low, it might make more sense financially, to swap in a used 2.2 motor. They can be had for not much money. That is what I did when I owned my 91 Leggie. im already of the same mindset. possibly look for a wrecked subie or something so i could have a parts car and yank the engine out Quote Link to comment Share on other sites More sharing options...
Olnick Posted June 30, 2010 Share Posted June 30, 2010 Here's the procedure for pulling codes on early OBD1 Legacies thanks to Josh-Legacy777. For reference, it's in the FAQ stickies at the top of the forum page. http://www.surrealmirage.com/subaru/engine.html And I agree that you'd probably be wise to look for a replacement engine. Good luck. Quote Link to comment Share on other sites More sharing options...
lone500 Posted July 1, 2010 Author Share Posted July 1, 2010 did a compression test today. the cylinder on the same side with the bad one registered 150 psi. the bad one registered 15 psi. guess its toast and time for a new engine huh? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted July 2, 2010 Share Posted July 2, 2010 I'd still pull the head first. You never know it might be a burnt valve. I somehow got "oily black gunk" stuck in my head. After re-reading, I just see "nasty black gunk", nothing about oil. No oil in the cylinder is more indicative of a burnt valve than a cracked or melted piston. Though the latter is still possible. Quote Link to comment Share on other sites More sharing options...
