Yes, I haven`t gotten a answer to this question. Does anyone know the torque ft. lbs on the 2001forester flywheel manual?...the crankshaft bolts and the bolts on the back of the flywheel that holds that thin plate to the flywheel.
Thanks,
Roger
Thanks,
Roger
Of the cars I've done, everything from chevy to ford to subaru and volvo, they'are all around 65 - 70 ft lbs for the flywheel to crank bolts. And 10 - 15 ft lbs for the pressure plate to flywheel.
This car has the 2.5 right? Should be the same as any other soob with the 2.5. If you search I'm sure you can find the FSM for an 01 model something or other with a 2.5 floating around here somewhere.
