Just checking some stuff
1. Yes - remove the small brass screw.
2. It's another ported vacuum supply - probably used for different styles of linkage systems. You don't need it so don't bother with it. That's why it's capped off similar to the EGR supply - most folks aren't going to use anything but the disty advance.
3. Not related to the EGR. Just another vacuum supply to be capped if you aren't using it (I don't).
You should pickup an EGR valve from an SPFI vehicle or an EJ engine. They don't have the AAV port so you could eliminate all that junk as well - it's not needed with the Weber.
