95 Outback, 158k. Stops great, no fluid leaking anywhere. If I stand on the brake pedal at startup it will be fine then about 3 seconds later it sink down lower. I did get an ABS light come on earlier where I had an idiot abruptly stop in front of me. The light went off when I restarted the car.
Brakes needing bled?
Just to ask a few last questions for my sake.
Doesn't sound like air in the lines or ABS unit?
How do I go about changing this thing?
It is very simple. Look at a haynes manual, but it is very straight forward. Use line wrenches for the brake lines. No need to mess with the ABS and it is all startight forward to bleed.
before you get a new master cylinder, double check your ABS codes, my 94, lego will sometimes sink a bit when i'm at a stop, but it will throw a code and the pedal feels as if the ABS is kicking in.
A quick reset of the ignition and its good to go again.
New master cylinder installed this evening. No more Titanic brake pedal.
Not a bad repair at all.
Congrats on the MC install. It is always satisfying when a do it yourself project is successful. Drive your Subie another 100K miles!
