wtdash Posted July 7, 2010 Share Posted July 7, 2010 (edited) DA of the day award: Didn't label the wires when I pulled them to swap the engine. The OEM replacements aren't labeled either. There are 2 the same length and the other 2 are both different lengths - one is much longer than the others. Does it matter where they go as long as the right port on the coil goes to the correct cylinder's plug? I've searched and either it's not here or using wrong search terms. I remember my Dakota's V8 had a different length wires and they had to go to the correct cylinder from the distributor....so just checking. Thanks Td Edited July 7, 2010 by wtdash Link to comment Share on other sites More sharing options...
3eyedwagon Posted July 7, 2010 Share Posted July 7, 2010 The ones on your Dakota "had to go to the correct cylinder" because they had to reach each plug correctly. If you mix them up on a v8 you'll often end up with some that don't reach, and others too long for where they are. There weren't special wires for a certain cylinder, just ones cut to the length to reach THAT spark plug. Other than that, it doesn't matter. Just route them the best you can in relation to which length is needed to reach from the distributor to the plugs. That's why they make them different lengths, and not all just really long. That way you don't end up with a pile of excess plug wire sitting on top of the air cleaner. Link to comment Share on other sites More sharing options...
idosubaru Posted July 7, 2010 Share Posted July 7, 2010 no, it doesn't matter. electricity travels the length of the spark plug wire in 0.000000003 seconds, so a few miles probably wouldn't even matter at those speeds! Link to comment Share on other sites More sharing options...
wtdash Posted July 7, 2010 Author Share Posted July 7, 2010 Thanks guys....appreciate the replies. Link to comment Share on other sites More sharing options...
Allpar Mod Posted July 8, 2010 Share Posted July 8, 2010 The only thing excess length on wires is of concern is if they contact parts that may cause chafing or get burned from the movement and vibration of the engine. Make sure the wires stay away from the block and other assorted parts. Link to comment Share on other sites More sharing options...
