Found location EGR Solenoid!!
Hi all again!!
Thanks for ALL the posts about our friend the EGR Solenoid! I scoured my Chiltons repair manual! I found a real break down of the Solenoid! It's part #7! It's for the SPFI 1.8 ltr engine. I hope you all can see it!
You have to cut & paste to see PIX! This server won't allow "Hot-Linking"!
Many thanks!! SubeeTEd
http://tedztoyzz.freewebpage.org/EGR3.jpg
Just remember, you can substitute a good purge control solenoid (the one that looks the same as the EGR solenoid, just to the left as you look under the hood) if you cannot find a good EGR solenoid. Just splice the connector from the old EGR solenoid onto your good purge solenoid.
BTW, here's a link to the factory test procedure for testing EGR solenoids - it's on page 122 of the PDF.
http://www.finleyweb.net/docs/SubaruEA82-ServiceManualPart1.pdf
And the entire test procedure for a code 34 is on page 71 of the second section of the PDF.
http://www.finleyweb.net/docs/SubaruEA82-ServiceManualPart2.pdf
My suggestion would be to run off these PDF's and put them in a binder. They will be so much more help to you than your Chilton on fixing engine and electrical problems. Bummer Jon Finley only put these sections on the web - of course, he has airplanes so he doesn't care about the rest of the systems!
